VFR Swingarm into RRV
+5
wilki666
Cleggy
9 posters
Hi all.
Cleggy here, just joined your fine site as i've just got my habds on a RRV in very good condition, Unfortunatly the purists amongst you will be sad to here I plan to streetfighter her.
I fancy a Single sider and i recon a VFR swinger will go in, but I'm not 100% on it.
Theres a VFR 800 swinger on evilbay for about 100 quid
Has anyone done this?, will it go straight in?
I'm also wanting a top yoke conversion if anyone can point me in the right direction.
Thanks Fella's
cheers
Cleggy
Thanks Fella's
cheers
Cleggy
Re: VFR Swingarm into RRV
Here's details of a tried and tested conversion on an RRS..
You will need the complete swinging arm assembly, except for the suspension linkages and shocker off a VFR FP-FS model, the rear brake hose off the above, and a spacer made up 25mm Diameter 20mm long with a 20mm hole in it.
Jack up the rear of the bike by putting a piece of pipe through the rear footrest hangers and support it with axel stands.
Remove the chain and disconnect the rear brake hose at the master cylinder.
Remove the shock absorber top mount bolt and then the bottom suspension linkage to frame bolt.
Remove swinging arm pivot bolt and entire swinging arm assembly.
Insert VFR swinging arm except for wheel and insert pivot bolt. Now on the clutch side of the frame, remove the threaded adjuster bolt and push in your machined spacer and re-fit adjuster. Take up all the play in the arm using this adjuster and then tighten the pivot bolt nut.
Re-fit shock absorber and all it's linkages as per stock swinging arm.
Fit VFR brake hose and bleed the rear brake.
Fit VFR wheel.
Use your stock Blade chain with the VFR socket.
Fit VFR wheel.
Hey Cleggy...I have a vfr in the back of mine...if you need any pics or owt PM me mate
funny how we all seem to play on the same sites eh!
Found this a conversion on a '98
Before...
a 1994 Swingarm..
This is the Spacer on the right side. It's 20mm long by 25mm Diameter and a 20mm hole for the pivot.
He added these washers to guarantee clearance between the shift linkage and the swingarm.
He ended up with better clearance from the washers in the previous picture.
This is the brake line from the VFR, But the brake lever and reservoir from the CBR.
Here's it fitted..
and with a '99 wheel..
The 5.5" rear wheel from the 99 VFR is very close to the 94 VFR swingarm.
plus being a newer wheel it had to be notched to fit on the hub..
Before...
a 1994 Swingarm..
Here's it fitted..
Nice post Alsieboy, didn't think an 800 arm would fit. Mine is a 750 Arm. Just been offered a wheel n arm for £200 on Streetfighters mcc site if anyone interested?
megawatt wrote:Nice post Alsieboy, didn't think an 800 arm would fit. Mine is a 750 Arm. Just been offered a wheel n arm for £200 on Streetfighters mcc site if anyone interested?
Look again, it's a 1994 arm with a 1999 wheel, the notches on the wheel are to clear the nuts on the '94 swingarm
It does look good though!
hi just about to do the same conversion, does anyone have a spare spacer they wouldn't mind selling me?
I'm going to do a slightly different conversion & fit a triumph 955i hub & wheel which will give me a 6.00 wheel over the 5.5 wheel of the vfr800 & all being well I should be able to run with a wider tyre. Just waiting for all the parts to be delivered & then the fun will begin!
All my parts arrived yesterday but the breakers on eBay sent me a 90-93 swingarm & not a 94 as advertised so that will be going back & now I'll have to source another one
Just sourced myself another VFR sssa, it'll be a couple of weeks until I can get started but when I do I'll post up my progress
thanks very much, very helpfull. Been playing with this idea for a while, but if its that simple, id be stupid not to do it!
one thing tho, which years of vfr swingarm will fit my '97 blade? or would any year fit?
making the spacer is no problem, being an engineer does help a bit
cheers for any help
cheers for any help
wilki666 wrote:thanks very much, very helpfull. Been playing with this idea for a while, but if its that simple, id be stupid not to do it!
Hiya mate, you will need a 94 to 97 arm
nice one, thanks for the help
just need to go and find a swingarm now, shouldnd be too hard.
shame, cause my dad has a '89 vfr, was planning on nicking his swingarm :L (hopefully he wouldnt notice haha)
wilki666 wrote:nice one, thanks for the help
Your welcome mate!
The differences between the arms can be seen below.
This is the pre 94 arm & as you can see the linkage is totally different from the underside of a blade arm.
& here is the 94-97 arm which has the same type of linkage as a blade swingarm.
The differences are worth noting as a lot of sellers out there don't know the difference & will sell you the wrong one.... like what happened to me! lol
what year would i need for a 95 rrs plz
spud3737- New Member
- Number of posts : 9
My bike(s) : rrs
Registration date : 2010-08-28
spud3737 wrote:what year would i need for a 95 rrs plz
Hi mate, all blades from 92-99 use the same swingarm off a 94-97 vfr just make sure the linkage looks the same as the gold arm
Where you been hiding mate ?
Kaiser wrote:Where you been hiding mate ?
Hey Kaiser! Let's just say I've been busy!
Well, good to see you back bud
Kaiser wrote:Well, good to see you back bud
Cheers buddy!
griz wrote:Kaiser wrote:Where you been hiding mate ?
ooooooowwwwww another project ?
zx12 with a turbo.
shadow wrote:griz wrote:Kaiser wrote:Where you been hiding mate ?
zx12 with a turbo.
lol oh how I wish.... Sadly no shadow.... The only project I have nowadays is myself! lol
Hi Griz, nice to hear from you.
cabbie wrote:Hi Griz, nice to hear from you.
Liking your work Cabbie, ( Vid's in signature strip )
Hiya cabbie, cheers mate!
Kaiser wrote:cabbie wrote:Hi Griz, nice to hear from you.
OMG got to agree with that! Quality!!!!! lol
» Helrazzer's Fighter
» rsv Aprilia swingarm in to 97 fireblade
» Stretched swingarm
» 954 rear wheel in my RRW swingarm
» chain line with single sided swingarm
