rsv Aprilia swingarm in to 97 fireblade
Hi
I am new to the forum and need advice on fitting a Aprilia rsv swingarm in to my streetfightered 97 fireblade, what year of rsv swingarm will
fit best and will i be able to use the fireblade rear wheel disc ect any advice will be helpful thanks:)
Phil C- New Member
- Number of posts : 5
My bike(s) : 97 fireblade
Registration date : 2013-02-10
Re: rsv Aprilia swingarm in to 97 fireblade
Just get an 04 Mille swinger, grind off 4mm from the right inside boss on the frame, arm will go straight in with the blade hardwear.
Get some longer 8mm bolts and a pack of washers to realign the suspension linkage, job done.
Don't bother trying to fit the blade wheel unless you have a lathe and good fabrication skill's, just get a set of cheap Mille wheels.
rsv swingarm
cabbie wrote:Just get an 04 Mille swinger, grind off 4mm from the right inside boss on the frame, arm will go straight in with the blade hardwear.
Thanks for the info will get on and try and track some parts down , when you say the right side of the frame is that the clutch side if you
look from the back .
Phil C- New Member
Yep, you don't have to get it perfect just as long as the swing arm goes in the gap, the screw in spacer touches the swinger.
rsv swingarm
cabbie wrote:Yep, you don't have to get it perfect just as long as the swing arm goes in the gap, the screw in spacer touches the swinger.
Thanks mate is the 2005 rsv swingarm the same as 2004 and will 2003 wheel fit.
Phil C- New Member
2004 swing arms are recall's but you just need to weld up a rivnut hole to make it safe, 2005 are the new design swinger, not sure about the 2003 wheels, go look at the Mille microfiche and see if the wheels are the same part numbers, I think they should fit ok.
rsv swingarm
cabbie wrote:2004 swing arms are recall's but you just need to weld up a rivnut hole to make it safe, 2005 are the new design swinger, not sure about the 2003 wheels, go look at the Mille microfiche and see if the wheels are the same part numbers, I think they should fit ok.
Can not find a decent 04 arm but found a 05 just wondered if the 03 wheel will fit
Phil C- New Member
Check the part numbers on the 03 and 05 wheels, if the part numbers match the wheel will fit.
rsv swingarm
cabbie wrote:Check the part numbers on the 03 and 05 wheels, if the part numbers match the wheel will fit.
Thanks mate will look in to it.
Phil C- New Member
I know this post is a year old. But does anyone know how difficult it is to fit the matching Aprilia wheel on the front of the same bike with the 1000rr fork conversion?
womack616- New Member
- Number of posts : 1
My bike(s) : 94 CBR 900RR
Registration date : 2014-04-05
» Helrazzer's Fighter
» VFR Swingarm into RRV
» Stretched swingarm
» 954 rear wheel in my RRW swingarm
» chain line with single sided swingarm
