my sc28 fighter project from NORWAY
Page 10 of 19
Page 10 of 19 • 1 ... 6 ... 9, 10, 11 ... 14 ... 19
Re: my sc28 fighter project from NORWAY
Update....Here is my new rear wheel axle,just finished, i chose a extreme tough steel. The wheel axle is 28mm thick and 470mm long with M25 x 1.5 nut, It's Temporarily used as a fight baton..........;o)
Update.Today i made an linkage mount for the shock absorber, i had to use the lathe to get the correct inner diameter for the needle roller bearing..
I need to weld this on place after I have mounted everything up and I'll probably need to make some new triangles too,,,,?
Nice work mate! probably will need to fab up some triangles with the new swingarm. I bet you can't wait to see it all on the bike!
griz wrote: I bet you can't wait to see it all on the bike!
Nor can we!
Hello Bladers,,The snow is finally gone!!! Today i tested my 300 swingarm and i got a minor problem with the the shock absorber, the spring almost touches the swinger, i got about 3mm clearance and i tought of shaving the top shock absorber mount about 5mm i should then have 8mm clearance. It's enough i think? enyways herz piczzz
Nice to see some progress with the build!
Nice progress mate. I bet your so glad the snow has gone!
That backend is gonna look massive!!!
updates: Today i made a pivot collar to my swingarm and a spacer on chain side..... collar/plain steel and spacer/stainless steel.
Clearance issue solved? 5mm slice cut/right side..
Sorry for the crappy pic,, do u see the internal snap ring! this fucker made me mad, i didn't have internal circlip plier..SO... i spent some time with it!
rapid777 wrote:
Nice!!
Is that an aftershock??
fastbikefinder wrote:rapid777 wrote:
Nice!!
Yes Walter mitty
Hi all,,I tested the EMC aftershock.. lol, and guess what * hell * the emc had 5mm wider spring! as for now i am in the same clearance posision as last... fark.. ok switched to another alternative,where i stole the spring from HONDA and of course it went to hell ,,the spring was to small for the cylinder body no no no. I will cut some space in the swingarm, i thought of a aluminum tube in 120mm inside diameter and with 5mm wall/ slice it in two and weld it on place?
I redid my pivot collar ,it was too heavy! made it lightweight
New needle roller bearings 40x30x30!!! just fitted, missing only the dustseals ,,I mounted in a grease nipple also. I am now waiting for a good welder/ aluminum welders does not grow on trees!
Some finished bling bling
looking good mate
scotty80- Website/Forum Owner
- Number of posts : 846
Thanks mates...
This will never work!!!! I'll have to sell the swing arm with the original wheel of width 5.5, maybe VFR 800 SSSA would be better to modify to a 280 setup?
This bike has less offset! with the 280 setup, but i think it has the vfr 800 sssa? and maybe some frame mods?
» RRN Fighter Project
» Megawatts Fighter
» Megawatts Fighter
Page 10 of 19
