929 RRY front end on a 98 RRW
Big question guys will it fit or can I make it fit? Can I fit my RRW discs and calipers to em or do I need to make spacers, brackets etc. They are at a good price and don't wanna miss em.
Re: 929 RRY front end on a 98 RRW
megawatt wrote:Big question guys will it fit or can I make it fit? Can I fit my RRW discs and calipers to em or do I need to make spacers, brackets etc. They are at a good price and don't wanna miss em.
Hiya mate, yes they will! I did it on my old rrw.
All 929 & 954 frontend parts are inter-changeable as there as good as the same!
You'll need to use either a 929 or 054 lower yoke which is a straight fit to the rrw & you can use thee rrw head bearings too & knowing that yours is a fighter you can use a sp2 top yoke which will fit sraight up & give you a flat top yoke to mount your handle bars!
I'm pretty sure you can use the rrw brake calipers but not the brake disc's.
So to make it work you'll need 929 oe 954 forks, yokes, front wheel, spindle & spacers. You'll also need the clipon's if you want the standard handle bar setup, oh yeah you may want to consider changing the front brake master cylinder to as the 929/954 have bigger brake disc's too
Nice one Griz , I knew that you'd know. will buy em tomorrow. Top SF man!
megawatt wrote:Nice one Griz , I knew that you'd know. will buy em tomorrow. Top SF man!
Your welcome mate, glad I could help
what size discs does the 929 have? mine are standard rrw310mm
megawatt wrote:what size discs does the 929 have? mine are standard rrw310mm
https://firebladeriders.forumotion.com/official-specs-f95/2000-cbr900-rry-t2643.htm
» My new front mudguard
» Off set front sprockets
» My new paintwork
» RRW front mudguard conversion
» Road legal projector lights to fit into front fairing?
» My new paintwork
