My 94 Streetfighter Project
+28
gothy
morgs887
macca
bladaz
J.J.
32 posters
Page 3 of 25
Page 3 of 25 • 1, 2, 3, 4 ... 14 ... 25
Re: My 94 Streetfighter Project
I do like the colours, excellent job, have a good xmas.
mr pie- MotoGP Legend
- Number of posts : 1251
My bike(s) : Bandit 600, CBR RR3 954
Registration date : 2008-02-08
mr pie wrote:I do like the colours, excellent job, have a good xmas.
Cheers mate, you have a good one too!
cool mate
making quick progress...putting me to shame!
radiobloke wrote:cool mate
Thanks matey!
Yep doin my best to get it done as I want it finished but for now havin a well deserved rest.
You'll be putting me to shame with your turbo spondon easy mate
If you cant get the tyre to pop on the rim,try and put a Rachet Strap around the tyre and squizee it,that,ll force the bead onto the rim better and then you,ll only need 40 or so psi to inflate
Haggler ®™- Global Moderator
- Number of posts : 1243
Haggler wrote:If you cant get the tyre to pop on the rim,try and put a Rachet Strap around the tyre and squizee it,that,ll force the bead onto the rim better and then you,ll only need 40 or so psi to inflate
Thanks mate!
I had 100 psi in it yesterday & put a pair of small ratchet straps around it, I did them up as tight as I could & ended up bending the ratchets it forced the tyre about another 10mm higher but it still didn't pop up, I bounced the tyre & whacked it with a rubber mallet but no joy. Come the end I had to cut straps off & let a load of air out to take some strain off the tyre.
I'll get another heavy duty ratchet & do it tight with very little air in it & then put some air in it & hope for the best
those parts look stunning Griz !
it's gonna be a beauty
J.J.- BSB Racer
- Number of posts : 257
My bike(s) : 2000 R1
Registration date : 2007-11-12
Try letting the air out and putting alot more lube on it so that it moves easier...!!!!!!
Try removing the shraeder valve , then rapid fill with a high flow. high pressure airline at a truck tyre maintenance place. Once the tyre is vacuumed to the rim put the valve back in.
megawatt wrote:Try removing the shraeder valve , then rapid fill with a high flow. high pressure airline at a truck tyre maintenance place. Once the tyre is vacuumed to the rim put the valve back in.
Yep cheers mate! Will do as soon as the garages re open
J.J. wrote:those parts look stunning Griz !
Cheers J.J.
Looks like a magazine cover photo shot is heading you're way.
AWESOME mate, how long till completion?
cabbie wrote:Looks like a magazine cover photo shot is heading you're way.
A magazine cover hey! Who knows!
Thanks matey! I'm going at it as hard as I can but I expect it'll be another month or 2 until I'm done. Part of the problem when you start on a project like this is deciding when to stop modding & start rebuilding
Hi all, I sent off a few more parts for powder coating & finished stripping down the engine, just gotta clean & paint the block next.
Its lookin a bit bare!
Its looking great. Those wheels look fantastic
skidd1- BSB Racer
- Number of posts : 300
My bike(s) : rrv, sprint st
Registration date : 2008-09-11
Woohoo!!! At long last I found a garage that could pop the tyre up on the rim! They had to put 145 psi in it & a whole lot of lube to make it pop but at long last it's sorted.
I've been busy degreasing the engine getting it ready to paint, the powder coaters should start powder coating the rest of my parts next week, there a bit slow due to being so busy but when has any good company quiet hey!
griz wrote:Woohoo!!! At long last I found a garage that could pop the tyre up on the rim! They had to put 145 psi in it & a whole lot of lube to make it pop but at long last it's sorted.
Wow! Thats a shit load of pressure man.
Glad you got it sorted Griz.
1992fireblade wrote:griz wrote:Woohoo!!! At long last I found a garage that could pop the tyre up on the rim! They had to put 145 psi in it & a whole lot of lube to make it pop but at long last it's sorted.
Yeah it was, the chap was flinching a bit lol
Cheers mate, I'm glad its sorted too, I was starting to worry it wouldn't fit or they would blow it up & I'd have to fork out for another tyre
Hi guys, After a lot of cleaning of the block I started painting it today.
I used very High temp paint (1500f) on the head which is flat black & then used satin black paint (500f) on the lower cases but I'm not happy with the different finishes.
So my question is do you think I can use the 500f temp paint on the head as well (which I'd prefer to as I have more of it) or should I stick to a higher temp paint on the head & just spray the whole block with the high temp paint?
Before I started.
After the clean up.
& now after a few coats of paint. The difference in colour can't been seen to the eye but my camera picked it up big time, to the eye the head doesn't look as glossy as the bottom half but still looks the same shade of black.
Before I started.
After the clean up.
Does look a bit odd with two colour blacks, I'd paint it all with the high temp paint.
I agree with Cabbie, it is noticable but still a fine job matey.
Looks like it's coming together nicely.
bloody hell Griz....howd you get the block that clean
'someone' has built up a RIIIght load of road crud on my engine and I need to do just what you have done...but have been putting it off....
did you use chemicals ( i heard over cleaner works) or a dremel sander?
gis a clue....cos I aint got one
'someone'
radiobloke wrote:bloody hell Griz....howd you get the block that clean
'someone'has built up a RIIIght load of road crud on my engine and I need to do just what you have done...but have been putting it off....
Well I used Mr muscle oven cleaner! but in the past I've also used some of the heavy duty bathroom cleaners too (the foam type) I gave it a good spray & left it for a hour & then gave it a seond spray & left it for another hour or so & then wiped off the excess & then got my little hand held steam cleaner on it (only cost about £15 on ebay) I gave it a couple of blast's all over & then I put some brake Fluid all over it but to be honest that didn't make much of a change. So I coated it with some white spirt & again steam cleaned it (wear a mask whilst doing any cleaning with chemicals!!!) & what was left was a thick layer of grease free corrosion. So I then brushed it up with a wire brush & with the more stuborn places & got my hobby drill on it & then finished it by sanding with sand papper & then after a lot of bleedin work & time I ended up with quite a clean engine but not perfect.
Be careful with the hobby drills as it will mark up the alloy very easily if your not carefull.
I think I might invest in a cheap hand help sand blast for any future projects though as it's a lot of work.
Have fun matey!
P.s that raod crud wasn't me as I never got it on the road!
Here it is now after its final coat (I say final coat but I still have to spray the rear of it yet) I coated it all with 500f temp gloss black paint & I'm pretty happy with it. It looks more grey in the pics but I promise you it's jet black.
Thats cleaned up nicely Griz & looks very nice mate.
When I use to clean up engine parts for my old minis & beetles I always use to use TFR (like truck wash) & non-acidic wheel cleaner. Keep applying it, leave it a while wipe of excess grud & re-apply etc then blast off with the pressure washer.
Smaller parts use to get the Mr.Muscle treatment then put them in the dishwasher...... providing the wife was out! Lol.
Sssshhhush! She still doesnt know! Lol
Looks good in black, this bikes going to look ace.
1992 parts in the dishwasher
shadow wrote:Looks good in black, this bikes going to look ace.
Damn right shadow it use to bring them up a treat! Lol
A complete engine in the dish washer just do it when the wife is out!!
If you're going to paint 80 grit emery, plus elbow grease fetches it all off and provides a good key, followed by a quick spray with Alu-Cure worked in with a toothbrush.
Wash off in hot water and then dry with hot air (I have a little downflow heater).
The last few nights I've been doing the cases and sump pan on my 1979 CB750/900, which I've sprayed with PJ1 Yamaha Silver engine case paint (well I am Yammydave).
Not too shabby, eh?
[img]
nice tips...
sure I'll be fu*king mine up some time soon!
» DIY STREETFIGHTER MASK
» my rrv blade streetfighter
Page 3 of 25
