DIGITAL CBR600FI CLOCKS ONTO FIREBLADE
Post by scotty80 on Fri 26 Oct 2012, 12:11
Have fitted CBR600fi clock to my rrv, I will do a how to later, BUT here as some pics when fitted
Re: DIGITAL CBR600FI CLOCKS ONTO FIREBLADE
Post by lambchops on Fri 26 Oct 2012, 12:50
very nice Scotty, the wiring diagram was of use then Smile
Post by scotty80 on Fri 26 Oct 2012, 13:10
it was to a point as the colours of the wires wasn't the same as the 98 but after sitting with the haynes manual got it sorted and it ain't as stright forward as it is to fit to the 98s,Got to change the temp sensor fo a 98 or cbr 600 one and also got to get a speedo healer v4 too, But it's well worth it:)
Post by lambchops on Fri 26 Oct 2012, 13:17
indeed it is, they do look awesome dont they. I never tire of the startup sequence when I turn my bike on Smile
Post by scotty80 on Fri 26 Oct 2012, 13:23
I never tire of the startup sequence when I turn my bike on Smile[/quote]
I dont ether lol Smile
Post by cabbie on Wed 28 Nov 2012, 19:27
Scotty can you do a step by step with the wiring, I'm a tit with wires and would like to do this.
Post by cabbie on Wed 28 Nov 2012, 19:34
Post by scotty80 on Wed 28 Nov 2012, 19:40
yes mate it is but i found it was no good with the earlyer blades as the wires arnt the same and it s just a straight swap to the 98 99 for ours you need a 98 temp sendor and oil sender and a speedo healer v4 i will takec mine apart and note what wire goes ware and take some pics too and sen them over to you
Post by cabbie on Wed 28 Nov 2012, 19:46
Thanks mate, just bought cbr600 clocks for 50
So is that a cbr900 oil and temp sender?
Post by scotty80 on Wed 28 Nov 2012, 19:51
yes mate
Post by cabbie on Wed 28 Nov 2012, 20:00
ok will order 98 oil and temp senders, anything else I need?
Post by wes on Sat 01 Dec 2012, 20:02
Looks very nice there mate, quite fancy having a go at this myself Smile
Post by lambchops on Sat 01 Dec 2012, 21:48
easy for your bike Wes, I have the wiring diagram. Worst part is you have to cut the loom but 90% of the wires are all the same colour so its just a case of joining them up.
Post by cabbie on Sun 09 Dec 2012, 21:22
Is this the correct temp unit and oil sender
37750-KV3-951 and 35500-MJ4-024
