+30
Granville
89forever
geraldc70
farmer
1UP
clevermonkey
stephen918
pauleves
Fahren
kavanaj
Prunty
jmacdwlr
34 posters
Page 16 of 20
Page 16 of 20 • 1 ... 9 ... 15, 16, 17, 18, 19, 20
masterblader wrote:Bloody road hog, you'd give bikers a bad name 8 thou in top equates to 140mph.
HA!! Have you taken into account the gearing change due to the sprockets??
LC - Glad you managed to get out and do some miles - it must be difficult having such restraint in the right wrist
kavanaj- Trackday Novice
- Number of posts : 141
My bike(s) : CBR900RR-W, Husqvarna 500CR!!
Registration date : 2008-04-08
Haha mique it wasn't in top gear don't worry not ready to put that much load on it!
I'm running standard gearing now James, thought with the extra power would switch back to standard. Have noticed the speedo is out quite a lot though with the cbr600 clocks.. Put it down to gearing before but Had my mate tell me when we were doing 70 and my speedo was reading 59 so need a speedo healer to correct that
lambchops wrote:Haha mique it wasn't in top gear don't worry not ready to put that much load on it!
Good shout on the gearing! Gutted to hear about the speedo being out by that much though... I'm going to be running 15T front and std rear but I'm assuming I will need a speedo healer for my bike too then?? :( Money is starting to run out a little after those SP1 wheels...!!
Yes it will James, with the Vfr rear end I had a tooth down and the front and 1 up on the rear, was still a little out but not as much.. Thought going standard gearing would correct it but its made it worse :(
lambchops wrote:Yes it will James, with the Vfr rear end I had a tooth down and the front and 1 up on the rear, was still a little out but not as much.. Thought going standard gearing would correct it but its made it worse :(
D'oh!! Thanks John, yet another thing on the list.....
well bike is now fully run in and I have to say im a happy bunny
Went out to loomies with the brother inlaw on his 11 blade and had a bit of a mad couple of hours. so many old bill around it was a joke but managed to find some quiet roads and gave the bike a good workout. Power from 4 - 8k is much improved, much faster pickup than before, from 8 - 10 doesnt feel that much different but its hard to tell for sure..
Handling with the new wheels and rear arm is much faster and had some serious fun on the A272 toward winchester keeping up with the 11 bike through the twisty's and he's a fast rider.
Going to be a fun summer I can tell
Big thanks to Mique for the engine work, couldnt have done it without this mans help and I wish you a speedy recovery Mique. Will pop up to see you on the bike and give you a hand with the ebay stuff
Well not updated this thread for a while...
Went to see Cabbie last night and collected these bad boys
mono block calipers at last hehe, they look the part and cant wait to use them in anger at the weekend!! Thanks Cabbie, I also picked up that rear end for perhaps some fettling over the winter so watch this space!
Well few changes to the bike...
Looking good LC, Should give you a few extra ponies to play with next summer!
Tone- BSB Racer
- Number of posts : 495
Fair Play there LC its looking great so far
thanks guys, its only held together with sticky tape and blue tack to check the fit, its all appart again now for final checking and clean up before going for welding. loved the 900 engine mique built but just wanted more power! greedy man me hehe.. should have an easy 150 at the wheel and with the 900 short wheel base should be a blast to ride!
Redesigned the engine mounts and made them out of thin board to check the fit, I will then give them to the welder so he can copy them Have to do left and right as they are different.
is that a new frame LC or d you strip the old one back to bare metal?
Tone- BSB Racer
New frame Tone, couldnt bring myself to cut up my original or strip off the powdercoat! Managed to get this one for £60 with clean title on ebay! So she's an M reg now
Is this about Odiham mate? need the extra power for the flying kilo?
Yeah it will certainly help Wes
You don't hang about, forgive me if i missed it, but what engine is that ?
RR4 CBR1000 lump
That's the way.
well been in the garage tonight (again) not done much today, stripped my frontend down and removed the chain from the swinger. I also finished off the engine mount template and even sprayed it silver (what a tart)
I also started looking at the RR4 loom, well what a nightmare mess!! Thinking of mounting the rec under the beam where the old coils used to mount as this area is quite clear and perhaps putting the ECU next to it. The Rec wires will reach to this location but will have to put it on a plate so the heat can be dispersed properly. Fuse boxes perhaps on the bulk head behind the head stock.. not handy I know will be tank off to change them but they are huge buggers!!
Still need to buy head light loom and coil loom, I think I need the secondary fuel rail loom.. not sure seems to be loads of grey injector connectors there..
Little update, engine and frame are away at the fabricators getting the engine supports added. Expected back on the 18th so some time to kill.. Before they left my company I built the engine up with the airbox etc, going to need some tank mods to clear the airbox, thinking of using my tank as just a cover (gut the inside) and fit the RR4 tank underneath. All depends if the filler neck lines up properly, wont know until the engine is back so I can try it. pic
Im also fitting the 2012 clocks, have both wiring diagrams and have worked out what needs to be connected (I think) gear posistion indicator wont work of course as uses a switch in the gearbox for this on the 2012 but I think everything else should appart from lap timer. made a bracket and mounted the clocks to the 900 support
Also cleaned up my swinging arm and gave it a good polish up, frame will get the same treatment when its back
Great stuff.
update time, engine and frame are now back so ive started building the bike back up. going to rip it appart again to paint and polish but want to build it up first to get everything mounted. Its rolling now at least
Coming along nicely mate
clive1286- BSB Racer
- Number of posts : 496
Thanks Clive
Niiiice
Fine job.
Looks good mate
scotty80- Website/Forum Owner
- Number of posts : 846
LC... awesome dude, you must do a loomies run with us next year
Thanks cabbie, defo up for a blast next year can't wait
Page 16 of 20
