Page 2 of 20 Previous  1, 2, 3 ... 11 ... 20  Next
Post by lambchops on Fri 27 Jan 2012, 18:00
ah thanks, does it use the same hole as the rad mount bracket?
Post by masterblader on Fri 27 Jan 2012, 18:47
The rad is hung on a spigot on the right, at the rear of that spigot is a 5mm thread which the " Z " bracket is bolted onto is where the earth contacts should be located.
Male Age : 73
Post by lambchops on Fri 27 Jan 2012, 19:15
Ah thanks MB I thought it must be the same hole as couldnt find any others in the area. Thanks guys Smile
Post by lambchops on Wed 01 Feb 2012, 22:09
Good news today gents, have a look at this terrible video im sorry about the quality.
https://www.youtube.com/watch?v=abYWd4K31Wg&feature=youtu.be
Yep shes running yipee!!! Cant believe it she started after 5 seconds of turning over, the choke isnt mounted and doesnt stay on so had to hold it. I couldnt run her very long as needs pushing (carring) out of the garage as will kill me when all that paint and pipe paint starts to cure with the heat. But on first look no leaks at all so im over the moon tonight and a full warming up run tomorrow Even the clocks work perfect and are very cool with the rev sweep! they have 39,000 miles on though haha
Post by scotty80 on Wed 01 Feb 2012, 22:17
Glad its all coming together for you can't wait to see it al finished keep up the good work Smile
Post by lambchops on Wed 01 Feb 2012, 22:23
Thanks Scotty Smile
Post by jmacdwlr on Thu 02 Feb 2012, 08:32
awesome nice one mate bet that put a big smile on your face after so much work will definately be a worthwhile mean machine when done
jmacdwlr
Number of posts : 119
My bike(s) : 1998 RRW
Registration date : 2011-04-04
Post by Mick858 on Thu 02 Feb 2012, 08:48
The garage is the best place for it this weather, but it's coming along nicely. Some worthwhile upgrades being added and it's looking super clean too. Did you go for that front wheel you found?
Post by lambchops on Thu 02 Feb 2012, 08:57
Thanks Mick, still watching the front wheel on ebay to see what it finishes for, realy need one now as the rest of the bike is getting close, having it running made me realise the end is now in sight. I was expectingn to have to do some troubling shooting because it wouldnt start etc, I was made up when it started!
Ive just gone and bought some fresh fuel and will wheel it out the garage for a full warm up later, just have to worry its all going keep sealed when its up to temp and my clutch is put back togther correctly as I cant move it with my hand (cable ist attached yet) Im hoping its just caught where its been sat for ages without oil in. Has oil in now though of course haha
Post by lambchops on Thu 02 Feb 2012, 17:46
Well moved the bike outside today as best I could without a front wheel! And warmed it right up until the fan kicked in several times. Noticed a tiny drip coming from coolant drain bolt so tightened it up and then noticed I hadnít tightened the oil drain bolt whoops, lucky I didnít dump all my new oil all over the floor while the bike was running could have been a disaster!
Anyway apart from those minor points it all fine, so now ive removed the tank as im going to sell it as itís too nice to paint so will buy another tatty one which can be prepped and painted. Iíve also added the cold air defector thing which sits under the frame support and keep hot air away from the airbox intake and roots cold air in. This was a bitch to fit as should have been added awhile ago but got there in the end. So now airbox is all fitted up properly.
Anyway couldnt resist a better vid
https://www.youtube.com/watch?v=oV1MSrbIlrc&feature=youtu.be
and a pic
Post by lambchops on Wed 08 Feb 2012, 19:20
Not too much progress at the moment, appart from sourcing the front wheel which you all know about thanks again Clive.
Been toying with the idea of having my forks redone so they look a bit like ohlins, tops anodised gold and bottom casings powdered silver. There is a company called firefox racing which for £430 will do this for you including a set of titanium gold lower tubes. They have quoted £150 to have my standard steel chrome lowers DLC coated gold or black but that could be stretching the budget at the moment..
Anyway the anodisors quoted £25 per leg to polish and anodised the upper tubes gold which I thought was a bargain so thats going to be happening Smile (forks are CBR1000RR ones just to remind you all) so now I need to strip the forks... Ive asked MasterBlade and he could be up for the challenge of stripping and reassembling afterwards love
Post by lambchops on Fri 10 Feb 2012, 18:10
Well started striping one fork today, downloaded the cbr1000 manual and decided the job didnt look too bad so would attempted it. Well things went bad from the off :( loosed the big fork top nut as per the manual no problem, then you have to hold the threaded section with a 12mm spanner (has a small cut out to locate the spanner) and with another 19mm spanner loosen the retaining nut, well started undoing and the 12mm spanner sliped and damage the thread slightly.
Once the thread is damaged the outter nut catches on the thread and the hole assembly just spins and you cant hold on to anything. So the end result now is the forks are stipped down but the preload adjuster area is completly chewed up and mangled as had to hold it with a pliers. :( Cant keep it like that looks terrible so looks like I need a whole new internal cartridge just to replace the tiny preload area. Thankfully there is one on ebay at the moment for £10 with 4 days to run so hope I can get that.. Bloody nightmare! Looked at the honda dealer and they are £430!! WTF
Anyway have the other one to start /ruin tomorrow wish me luck Laughing
Post by lambchops on Sat 11 Feb 2012, 22:52
Well forks are stripped at last, managed to get the second one appart without chewing the hell out of it so that was a result at least.. Here are the upper tubes ready for polishing and anodising.
I also powdercoated the fork lowers silver as not keen on the bronze, may even look like a well known Swedish fork manufacturer when im done haha
Post by wes on Sun 12 Feb 2012, 17:03
Did you do the powdercoating yourself ? looks really good thumbup
Post by lambchops on Sun 12 Feb 2012, 17:18
yes I did Wes, have one of those DIY machines. Cant recommend it enough tbh its as good as anything ive had done professionally. The only limit is the size of the oven im using Smile I did do my 16" blade front wheel black and came out better than the rear which wouldnt fit in the oven as was done professionally.
Post by wes on Sun 12 Feb 2012, 17:41
spot on mate, fair play, looks very professional Smile
Post by lambchops on Sun 12 Feb 2012, 17:53
thanks Smile just did a mock up with my brembo rep calipers attached to the castings with the disk in place does look very nice Smile
Post by Tone on Sun 12 Feb 2012, 22:33
Thats starting to look like one nice scoot.
wish I had half your spannering skills!
Number of posts : 495
Male Age : 117
Post by lambchops on Sun 12 Feb 2012, 22:50
Thanks Tone, theres no great spannering skills here though I can assure you. If I had posted the mess ive made to my preload adjuster you wouldnt be saying that haha
Post by Tone on Sun 12 Feb 2012, 23:19
That may well the case but youve made more progress in the last mont than I have in the last year!!!
Keep it going its looking great.
Male Age : 117
Post by lambchops on Mon 13 Feb 2012, 21:39
went to the anodisers today to drop off my upper tubes and ask him if they could be polished and anodised gold please. He said what sort of gold would I like.. I said um gold please hehe. So in the end I removed my rear ohlins shock and said match it to that please sir Smile
I also powdercoated the other casting today and took a mock up pic with the calipers, quite pleased with how this is looking Smile
Post by clive1286 on Mon 13 Feb 2012, 22:35
Looking good LC, clocks look good i see you have fitted them to the original headstock mount with that great new mount so thinking what you doin about headlights or are you keeping the fairing and oe lights?. Seen some clocks for sale the same and thought about making a similar bracket to yours and mounting it to the underside of the top yoke so they will turn with front end.( i don't have the original headstock bracket) would have to allow for slack in the loom so it didn't tighten on full lock, still struggling with a headlight though. has the wheel turned up yet?
Post by lambchops on Mon 13 Feb 2012, 22:47
Thanks Clive, it going to be fully faired still so will be keeping everything stock up front. But those 600 clocks come with about 6 - 8 inchs of wiring so you have plenty of slack if you want to mount them on the bars somewhere. What year is your blade as needs to be a 98 - 99 otherwise you need a new temp senser and an electronic speedo drive if its still on a cable. Cant remember all the details for the older bikes but can provide you a link to another forum with all the answers Smile But dont worry about cable they come with plenty
Post by clive1286 on Mon 13 Feb 2012, 23:02
Thanks mate, mine's a 98 RRW same as yours
Post by lambchops on Mon 13 Feb 2012, 23:05
easy job then Clive Smile i love mine realy worth doing mate
Post by lambchops on Wed 15 Feb 2012, 10:34
OK so had the call this morning fork tubes are done, so went to pick them up and im very happy, that look awsome!! Heres a mock up pic, ignore the fithy windows and cats haha
Post by Prunty on Wed 15 Feb 2012, 13:32
Lookin Good, keep up the good work...
Prunty
Number of posts : 78
My bike(s) : 1998 RRW Urban Tiger
Registration date : 2007-11-05
Post by lambchops on Wed 15 Feb 2012, 14:06
thanks Prunty, im toying with the idea of having the stanchions titanium nitrate coated which is the gold coating on the ohlins forks, its the super slippy stuff to aid fork movment and then they would look super slick! Ive had quotes for £150 for both so im deciding if the budget can stretch to that.... mmmmmm gold..
Some info here :
http://www.reactivesuspension.com/services.php
Post by lambchops on Wed 15 Feb 2012, 15:40
Heres the wheel thanks again Clive it was a great find buddy still owe you that beer Smile
didnt come with rotors had those already
Post by Mick858 on Wed 15 Feb 2012, 16:33
That looks just the job, a great looking front end coming together. Are the wheels staying black?
