project whenever!
Page 3 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
look! Re: project whenever!
Post by clive1286 on Mon 02 Jan 2012, 19:55
Cheers Dave, Might be able to get an ally block made sounds a good idea. I'll see how the copper holds up to start with
Post by clive1286 on Mon 02 Jan 2012, 20:14
Cheers Lambchops, had a look at your build, impressed with the 800 arm, alot more involved than the 750. So thats an R1 rear ohlins? didn't realise they fitted. look forward to more pics. Say 'hello' in the new members section there's some great people on here.
Post by lambchops on Mon 02 Jan 2012, 23:53
Yeah 800 arm is more work but I hope its going to be worth it in the end, the r1 shock was another gamble I hope is going to work, it wouldnt clear the subframe but as im fitting a gsxr k3 rear undertray Im sure I can make it work with some mods Smile
Post by clive1286 on Tue 03 Jan 2012, 20:22
Hi anyone know if this will fit the rrw forks? will the rrw discs work? thought 3 spoke would look good with the vfr rear wheel
http://www.ebay.co.uk/itm/170756945668?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Post by lambchops on Tue 03 Jan 2012, 21:44
How did you do the rear brake line Clive as the hole doesnt look big enough to fit the banjo through? Do you have an end to make yourself?
Post by clive1286 on Tue 03 Jan 2012, 22:15
It was suprising easy to do mate. Got the line ( 1200mm) to be on the safe side from a company called Venhill, got them to fit the caliper end banjo fitting but leave the m/c end off,( its a compression fitting so pretty straightforward to fit). Took out the stub axle & hub then drilled the arm through the raised 'square' at the back (caliper end) ( as in pic) then took the shock off so i could get into the holes inside the arm where the shock fits. got some elec cable and pushed it into the hole i drilled at the back and started to push it through the arm untill it came out the hole on the inside of the shock, then drilled the front of the arm ( as in pic) then the fiddly bit was getting the wire round th inside of the shock mounting hole and out the new small hole i'd drilled, once it was out i then taped the m/c end of the brake line (end without fitting on) to the elec cable and slowly pulled it through, pushing the brake line at the same time until it eventually came out. I have left the cylinder end long until i get the exhaust link pipe made so it doesn't rub or i cock up and cut it to short I think it only took a couple of hours max to do but am pleased with the result. To be honest i 'borrowed' the idea from a guy called cbrrrt who has influenced me alot with this build, feel free to ask more if the above is as 'clear as mud'
Post by lambchops on Tue 03 Jan 2012, 22:22
Ah thanks for that Clive, is this legal for an MOT as I was thinking of doing this on mine but was worried about rubbing in the arm? Also where did you get the gromet? I have run some cable inside my arm incase I did this will defo attempt it now thanks Smile
Post by clive1286 on Tue 03 Jan 2012, 22:33
No idea about the mot ! guess i'll find out when i eventually get it there As for the grommit, the brake line came with 3 rubbers on it, i suppose to hold it in place in clips, but as i didn't need them i pulled them of the bare end and cut 1 in half, bingo 2 grommits!
Post by lambchops on Tue 03 Jan 2012, 22:37
ah great idea, i will give them a ring tomorrow and order one up. How much was it out of interest?
Im sure MOT will be fine, we will have to see who gets there first hehe
Post by clive1286 on Tue 03 Jan 2012, 22:44
cant remember exactly £34 ish i think
Post by lambchops on Tue 03 Jan 2012, 22:53
great thanks Clive
Post by clive1286 on Thu 05 Jan 2012, 15:51
This is how i found the RRW looking very sorry for itself !!!
This is more or less what it looked like apart from no tail plasics,exhuast or front discs.
That was 12 months ago, so its getting there.
Done a bit more today,
Click here to view the original image of 800x600px and 205KB.
decided i need to cover the gap between the R1 tail plastics and the frame, so i found some old perspex and made this
Click here to view the original image of 800x600px and 349KB.
Then with a hot air gun did this
Click here to view the original image of 800x600px and 238KB.
and ended up with this
Click here to view the original image of 800x600px and 245KB.
Then had a go at fibreglassing, think its the first time since i left school:Embarassed
Click here to view the original image of 800x600px and 364KB.
have to see what happens when it sets!!. plan is to go over it with filler and smooth it into the original tail section. Have done both sides now so hopefully tomorrow i can get the filler on
Post by shadow on Thu 05 Jan 2012, 16:19
Starting to take shape. Smile
I tried to repair a fibreglass fairing i got cheap, it didn't go well. Embarassed
I blamed the fumes, for me being so crap at it. lol!
Post by clive1286 on Thu 05 Jan 2012, 17:03
Cheers Shad, don't feel so bad now
Post by Mick858 on Mon 09 Jan 2012, 02:05
Nice work Clive, keep the photos coming.
Mick
Post by clive1286 on Thu 19 Jan 2012, 19:34
Managed to do a bit today got the seat unit filled and sanded. temporary fitted it then made a start on the seat
Post by clive1286 on Thu 19 Jan 2012, 19:44
Quite pleased with how its looking for a 1st time attempt at anything like this. Not sure yet about the front end where it meets the tank but its deffinately nearer than before i started. Need to get some more foam to cover the front sides i've extended, then think about re-covering it, whether i have a go myself or take it somewhere & get it done professionally. got the original off in one piece but have either got to make a complete new one or extend it to cover the longer sides and where it meets the tank. Hopefully get it sanded and fitting better 2moro
Post by lambchops on Thu 19 Jan 2012, 21:35
wow thats looking realy good Clive, youve earned a pat on the back there buddy Smile Amazing in fact for a first attempt!
Post by cub on Thu 19 Jan 2012, 21:38
Lookin good bud remeber the fibreglassing well, you'll feel dead chuffed when it's done
Number of posts : 84
Post by clive1286 on Thu 19 Jan 2012, 21:46
Cheers Guys, will post some pics when its sanded
Post by Guest on Thu 19 Jan 2012, 22:40
Well done Clive
Post by clive1286 on Sun 22 Jan 2012, 15:43
Finished!
decided against trying to make a new cover myself, so have taken it to a local classic car trimmer who's going to do it for me. Goin to be about 2-3 weeks though due to his workload so just gotta wait
Post by clive1286 on Sun 05 Feb 2012, 11:39
Got the seat back yesterday
Pleased with how its come out, just gotta try and get in garage to see what it looks like on the bike. Don't feel like shoveling loads out the way though! No
Post by Guest on Sun 05 Feb 2012, 12:10
That looks great mate!
Post by lambchops on Sun 05 Feb 2012, 12:27
yep have to agree thats come out realy well! Now get in the garage and try it on you lazy git Smile
Post by clive1286 on Sun 05 Feb 2012, 12:29
Cheers guys, don't think i'd have got it to look as good. snow's beginning to thaw quick now, might try & get in garage in a bit, put pics up of it in place if i do
Post by clive1286 on Sun 05 Feb 2012, 21:15
Managed to get the snow out the way and got in the garage, fitted the seat temp think its come out pretty good for a 1st attempt
Post by clive1286 on Sun 05 Feb 2012, 21:25
Changed some hoses while i was in there. Got these from a local performance car spares shop, need to get the smaller bore ones next
Post by Guest on Sun 05 Feb 2012, 21:36
Nice!
Post by clive1286 on Sun 05 Feb 2012, 21:42
After seeing a couple done decided to replace the baffles inside the cans ( you talked me into it Shadow)
Looking at the kits available on ebay approx £60-£80 inc shipping found this site
http://stores.ebay.co.uk/Custom-Exhaust-Parts?_trksid=p4340.l2563
Got me 1mtr length for £18 inc post.
going to re-use the original wadding
