R1 sub and seat to a 96 Blade
Post by CBRRRT on Sat 04 Sep 2010, 18:18
Not really so much of a how to, but more of a what I did
After a lot of messing about with proping the sub-frame, and getting the angle just right I was
able to make templates from a couple of bit of serial box.
I drew round them and added a few dims, so now you dont have to fark about with bits of string and shite like that. all you have to do is copy the template to your pix, print it off and use the dims to make your own mounting plates
When you've made the plates you'll need to drill a 10mm hole in the top of your R1 sub-frame. This will stop it rocking, and keep the angle set just right.
The sub-frame will then sit on the frame cross member
And the bottom plates are there just to secure the whole lot and make the set-up solid
Paint em black and the job's a good-un.
So there it is then, simple as that.
Number of posts : 143
Re: R1 sub and seat to a 96 Blade
Post by Guest on Sat 04 Sep 2010, 19:45
Nice one mate!!!
Post by CBRRRT on Sat 04 Sep 2010, 22:42
Hi bud, did you have a good holiday?
