Extended clutch cable
4 posters
What cable would fit my 97 Blade when I put the risers and bars on. Was thinking a slingy gixer but dont know. Dont wanna pay £27 at Streetfighterstore
cub- CBT Novice
- Number of posts : 84
Re: Extended clutch cable
For my rrv, i used the cable off a rrx, as it is routed differently.
Mine had heli bars to, so might work for your setup.
Megawatt will know for sure.
Got mine on eBay from Streetfighterstore a while ago, cost £15! If not find a good Britbike shop or try Venhills, but they won't be much cheaper???
I use the standard 1 routed under the tank.
Cheers for the info looking at 2 inch risers and same on the bars, was just trying to get the stuff before winter so I could crack on. Might look at re routing the cable, did you have any probs with the clutch becoming heavy due to doing that?
cub- CBT Novice
Nope.
The bracket at the clutch end needs a little persuading and it's a little tight/busy (throttle cable) around the head stock/front tank mount .
but apart from that its all good.
Fringe wrote:I use the standard 1 routed under the tank.
+1
Fringe wrote:Nope.
goes back when you put it to standard too
