Project Tigger
Project Tigger
Post by alsieboy on Wed 05 May 2010, 12:48
Postie brought a bundle of goodies this morning, so thought I would make a gentle start while the pain was at controlable levels this morning.
Clocks arrived so decided to see if the internals could be swapped over...
Original clocks..
Replacement clocks...
rear of speedo on the original clocks was smashed....
tip for you make a note of the wiring if your are going to attempt this cos it's not always that clear where the wires go..and seperate the screws cos there are different lengths too..
Broken part of casing removed and the internals are intact...happy days..
When removing the speedo dont forget the mileage reset roller which is held on with a very small cross head screw....
New clocks are split and the casing put to one side..
now the internals of the new clocks can be removed..
and replaced with the original internals
decided to re-use my original wiring loom...
Wiring all back in place
And voila.....refurbished clocks...sunny
Anyone have any use for this little lot...free to a good home sunny
Re: Project Tigger
Post by griz on Wed 05 May 2010, 13:08
Nice work mate! thumbup
Re: Project Tigger
Post by alsieboy on Wed 05 May 2010, 16:44
Deciced for the mid panels it's going to be more cost effective to respray them sandy beige metallic and shell out for the decals. Decal costs 70 a side as apposed to 200 + vat for a replacement mid panel. Had this panel kicking around the garage for a few years, seemed a shame to attatck it and remove the decals, but it's a mint straight panel which will paint up nice..
attacked it with a hairdrier to soften up the decal and it came off easily...
That's the right hand side mid panel sorted...
Re: Project Tigger
Post by alsieboy on Fri 07 May 2010, 13:13
Got the fairing brace at last with a complete set of fairing brackets for 40..
Happy days, going to be slow to update at first untill my back gets better, but looking forward to ripping it to bits and making a start proper
Re: Project Tigger
Post by Guest on Fri 07 May 2010, 17:06
Nice one Al, being busy on the bike should help dull the pain a bit. Worked for me!
Re: Project Tigger
Post by Fahren on Fri 07 May 2010, 17:17
good work!! look forward to the bit on adding the decals, mine are chipped and sorry looking on oneside so need to replace them.
Least now i know how best to remove them Smile
Fahren
Number of posts : 827
Registration date : 2010-04-12
Re: Project Tigger
Post by alsieboy on Fri 07 May 2010, 17:36
Fahren wrote:good work!! look forward to the bit on adding the decals, mine are chipped and sorry looking on oneside so need to replace them.
The mid panel decals work out at 180.10 the pair inc vat, compaired to 428.08 inc vat for a new pair of mid panels. Given that the decal covers 95% of the panel, worth going that route. sunny
Re: Project Tigger
Post by Fahren on Fri 07 May 2010, 22:25
even cheaper than buying second hand ones that might require re-spray!!...if u look at my mini pic its the lower panel purple triangle decal thats taken the worst damage from stone chips etc...(not that u can see it in that small pic lol
Fahren
Re: Project Tigger
Post by danidge on Sat 08 May 2010, 07:33
are you going to spray the panels yourself? how are you going to get the colour match exactly the same?
Male Age : 28
Re: Project Tigger
Post by alsieboy on Sat 08 May 2010, 09:41
I can get the sandy beige metalic and the claret, perfect colour match through a contact in the paint trade sunny
Re: Project Tigger
Post by alsieboy on Tue 11 May 2010, 10:36
more goodies arrived today....
A straight fairing brace...been staring at it for ages checking it wasnt bent, the more you look the more you convince yourself that something is wrong, but having got the tape measure out and checked it, it is straight..even in the pic I have took it looks out of shape ..lol!
Re: Project Tigger
Post by alsieboy on Tue 11 May 2010, 10:39
oh and a bag of fairing brackets for a tenner...
but looking at it, I think he has thrown in every bracket not just the fairing, looks like the seat panel brackets too..
Re: Project Tigger
Post by alsieboy on Fri 21 May 2010, 12:42
had a good day yesterday so had a fiddle with the bike....had the forks checked and the good news is they are straight, he losened the yolks and re-tightened to correct any slight movement that may have taken place and the scuff just t-cutted off the legs. Happy Dayz..
The clock bracket looks well buckled..
removed the remains of the damaged bodywork..
Screen is too scratched to be salvagable so will have to find another..
Can't beleive this inner fairing panel survived undamaged..
And the fuse box cover is un-damaged, more savings
Managed to strip out the bracketry..
Clock/fairing bracket had to be hackd up to release the wiring..
Fairing brace is scrap, but I got a new one..
Radiator was beyond salvation
And the fan housing was buckled
But the grill was intact and un damaged
New radiator in with second hand fan and original grill back in place
Clock/fairing bracket in with wiring re-routed and clocks installed
Getting there slowly........
Re: Project Tigger
Post by fastbikefinder on Sat 22 May 2010, 14:46
You've got a bit of dirt on the side stand foot.
Re: Project Tigger
Post by rapid777 on Mon 31 May 2010, 00:15
You will soon have the tiger up and running ;o)
Number of posts : 463
Re: Project Tigger
Post by Fringe on Mon 31 May 2010, 11:09
Great to see ya progress Alsie.
Are you recoverng too?
thumbup
Re: Project Tigger
