Fitting longer studs to your VFR hub to take a car wheel
Fitting longer studs to your VFR hub to take a car wheel Empty Fitting longer studs to your VFR hub to take a car wheel
Post by CBRRRT Mon 15 Feb 2010, 20:02
To fit a car wheel on your SSSA you are gonna need spacers, and yes longer wheel studs. Not a hard job to do and this is how I went about it.
Fitting longer studs to your VFR hub to take a car wheel 1257076133
I thought it might be a bit easier to do the job if I removed the sprocket first and got the chain right out of the way.
Fitting longer studs to your VFR hub to take a car wheel 1257058389
They are the little buggers I need to get to
Fitting longer studs to your VFR hub to take a car wheel 1256984547
So after I got the sprocket off the next thing to do was undo that big nut. I dont have a socket that big so used an adjustable wrench.
Behind the nut is a washer that needs to be removed carefully with a flat screw driver.
Fitting longer studs to your VFR hub to take a car wheel 1257060554
Once they are off the hub should pull off.
Fitting longer studs to your VFR hub to take a car wheel 1256986500
With a soft mallet, tap out the hub from the splined side.
Fitting longer studs to your VFR hub to take a car wheel 1257020448
I used my Haines manuel, but now all you have to do is follow this, happy days!!!
Fitting longer studs to your VFR hub to take a car wheel 1257078335
OK, in my socket set I have a bunch of sockets with 7/8" and 1 1/4" bollocks on them. I dont use them, I dont like them, and I dont farkin understand them so any chance I get to abuse them, I do just that.
Anyway, I stuck one of them in my vice and tightend down on it
Fitting longer studs to your VFR hub to take a car wheel 1257041886
I then placed my disc hub onto the vice with the wheel stud sat inside the socket. You know whats comming next dont ya!!??
Fitting longer studs to your VFR hub to take a car wheel 1256981238
A couple of sharp taps and out-ski she come-ski
Fitting longer studs to your VFR hub to take a car wheel 1257022314
Now up to now its only taken about half an hour, so not hard at all
Fitting longer studs to your VFR hub to take a car wheel 1257013039
And there they all are.
Fitting longer studs to your VFR hub to take a car wheel 1257055110
Now I have something I can go to my local car spairs shop with and ask for something a bit longer, Ow er Missus!!
Fitting longer studs to your VFR hub to take a car wheel 1257073004
Hub is 8mm + 30mm spacer + new wheel, so I'm gonna need something to cope with all that
Fitting longer studs to your VFR hub to take a car wheel 1257003662
I'm gonna do it with two spacers, 1 x 20mm and 1 x 10mm, coz I'm not a clever git with a lathe that can make one. When the 20mm spacer arrived it was just a nats cock to small, so I went round the inside with a round back file and took off a very small amount.
Fitting longer studs to your VFR hub to take a car wheel 1257050739
Then it popped straight on, and was a nice snug fit.
Right then, lets see if I can remember how this pile of nuts and bolts went together
Fitting longer studs to your VFR hub to take a car wheel 1257976001
peice of piss, there was fark all to taking it to bits, so putting it all back was a doddle.
Fitting longer studs to your VFR hub to take a car wheel 1258005509
The studs I used were 63mm long Ford studs (M12/1.5) The M12 is the size of the bolt and the 1.5 is the pitch of the thread. They have a 13.1mm spigot, thats the bit that bites into the hub. You'll need to drill out your hub to fit them, but if a numb nut like me can do it, then so can you.
Fitting longer studs to your VFR hub to take a car wheel 1258065922
I put the 20mm spacer on first as the back has hollow sections that sat nice over the disc rotor nuts. Then the 10mm spacer went on next.
Fitting longer studs to your VFR hub to take a car wheel 1258067439
Loads of room for the wheel, and plenty of thread fo my funkey wheel nuts, MAN!
Fitting longer studs to your VFR hub to take a car wheel 1257983009
Just need to get some rubber on my Inovit concept wheel and bung it on.
Fitting longer studs to your VFR hub to take a car wheel 1257997613
Now, I ask ya "How hard was that"
Fitting longer studs to your VFR hub to take a car wheel 1258412572
Fitting longer studs to your VFR hub to take a car wheel 1258412148
Fitting longer studs to your VFR hub to take a car wheel 1258497070
Fitting longer studs to your VFR hub to take a car wheel 1258467916
Fitting longer studs to your VFR hub to take a car wheel 1258455627
Fitting longer studs to your VFR hub to take a car wheel 1258439614
When the sun shines we shine together
Number of posts : 143
