painting brake calipers
Post by Guest on Mon 08 Feb 2010, 11:52
I've stripped all the old paint off my calipers and bought some acid etch primer. Can anybody recommend a make of paint for em. I'm told I need High temperature caliper paint, but could that be for cast iron car calipers?
Re: painting brake calipers
Post by rapid777 on Mon 08 Feb 2010, 15:23
Hi Megawatt
I don't think the heat will be a problem here, i rather think the brake fluid is worse ,causing discolour and damage of the paint lacquer.
http://www.g2usa.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=g2usa&Product_Code=G2
i found a how to do it on u tube. he he
https://www.youtube.com/watch?v=qRiyubFm8vc
Number of posts : 463
Post by rapid777 on Mon 08 Feb 2010, 16:24
i painted some calipers once,with black gloss, it never faded ,one day i did manage to spill a tiny spot with fluid and it killed the paint slowly even efter i washed it with soapy water. I redid my painting with caliper paint but then again it doesn't like brake fluid
(rem the real heat is from the brake discs)
Post by Guest on Mon 08 Feb 2010, 16:39
Yeah, that's what I thought. Most people advise , just use ordinary paint. Cheers mate!
