Planned Winter mods.
Post by Deathace on Tue 13 Oct 2009, 10:16
Thought I would put in here the mods I am planning for the winter period, I don't stop riding during winter otherwise I would never ride the bike but during part of its lay up I will be doing some bits and pieces to it, I have done the majority of the cosmetic mods to mine so far but there are a few outstanding.
this is the first to be done.
Before:
After:
As you can see on the stock/R&G tail the black section hangs down a bit making the tail look ok but still porky. With the subframe cut and braced on the top you can get the smooth lines and it looks more sleek.
Number of posts : 509
Male Age : 43
Re: Planned Winter mods.
Post by Kaiser on Tue 13 Oct 2009, 10:23
I like that mate
Like the levers
Post by reeseyboy on Tue 13 Oct 2009, 16:21
Where would the licence plate and indicators go?
reeseyboy
Number of posts : 207
My bike(s) : 2009 CB1000R - Sword Silver
Registration date : 2009-05-26
Post by fastbikefinder on Tue 13 Oct 2009, 16:49
You could put a stick on number plate on that underside, that'd keep it clean, then buy some yellow Led's and some pcb and make your own indicator system mounted in the side of the tailpiece on the underside.
Excuse my poor photoshop skills - But I've tried to show what I mean - with clear led's that would flash amber.
I like the clean look of the silver can - is that also planned with the gold levers and red grips, and finally the black casings you wanted last year?
Also Russ - where did you read about that mod? I'd like to have a read of it as I'm still wanting to change the rear end on my RR - I've thought of countless alternative rear ends to use but keep coming back to the '08's every time.
Post by Deathace on Tue 13 Oct 2009, 17:57
I had the idea last year fbf and the chap that did the above had the same idea it was spooky Smile
His solution was the same as mine but he obviously fabricated his bracket different to how I was going to (but his is better). I have since obtained some really nice thick aluminium plate so I can at least keep my bracket light and yet sturdy also it allows me to play about with milling by hand (*SHIT AINT DONE THAT IN YEARS*) to follow the contours of the subframe inside.
In regards to the undertail bit I have been honing my skills in the carbon fibre department with all the other bits and pieces for the mini motos it allows me to form it how I want and make bits to add to it for the plate.
The indicators idea is brilliant and one for me to look into but my primary solution is a set of Clear Alternative tail lights and then cut them down to fit the single line brake light look that big swede (the chaps bike above) did.
Because of my self confessed OCD I can't help but take what he did and make it better, neater, more OEM finish to it all so this is why I have been planning for a year but only now am I confident of what I want, how and the ability to do it without it looking like a pigs ear.
I will be using the carbon fibre for strength but fibre glass and paint for the finished surface I will also be reforming the lense of the rear light to allow for waterproofness after the modifications have been done to it (cutting down the board and electronics and integrating indicators).
In response to the gold levers and red grips no I am wanting to keep things subtle and OEM looking but with noticable differences over the next red blade. The levers I have are TITAX Foldables and I think they look great but in keeping with the original. The silver exhaust shield is what I had and hated hence the powdercoating to me it looked out of place being silver in a prominant place, bolts and fixings I dont mind silver along with forks and discs but the major big things like the rear sets and the exhaust and caliper bracket all seemed an afterthought with a black frame/swingarm/subframe.
I like things looking in my minds eye as pure genius and to tarnish it with little bits out of place just spoil it for me. I do have further cosmetic mods to make but they will all be performed after this one and when the photoshopping is finished.
Male Age : 43
Post by fastbikefinder on Tue 13 Oct 2009, 18:36
I forgot all about you powder coating the zorst and I've got so used to
seeing your posts of your bike I started thinking the black was original
Post by Deathace on Tue 13 Oct 2009, 18:54
thats a good thing from my point of view its doing the job intended Smile
Male Age : 43
Post by fastbikefinder on Sat 17 Oct 2009, 17:03
Can you post up a picture of the back of your bike please?
Just so I can see the undercowl of your tailpiece compared to yours.
Post by Deathace on Sat 17 Oct 2009, 19:08
A Few shots with the R&G tail tidy, I only have 2 pics of the stock and thats from the day I bought it. I ripped the arse off 20 mins later and swapped it out.
Male Age : 43
Post by fastbikefinder on Sat 17 Oct 2009, 19:28
Deathace wrote:
Thanks Russ,
Is that black under cowl thing the inner mudguard?
Has the guy in the states fabricated that red cowl under neath?
Is the standard RR8 rear light in 2 pieces?
Post by Deathace on Sun 18 Oct 2009, 17:38
Sorry m8 I misread the first request what you are after is the painted section below where I have shown, I will sort some pics out tonight when I get home and upload em afterwards.
The piece the yank fabrcated was the section that goes from the tail light underneath to the OEM section ( that you want pics of) as for the tail light its complete one piece with 2 steps to it, the yank again has cut the bottom section off the tail light to make it one strip (easily done).
Male Age : 43
Post by fastbikefinder on Sun 18 Oct 2009, 18:11
No more pictures needed at the moment Russ, thanks anyway.
Just wasn't sure what was going on up there, so I'm now assuming the black underside on yours is standard compared to the yank's fabrication.
A nice mirror polished ally job will no doubt cause havoc for any gatso's that are hiding round unknown bends
Post by Deathace on Sun 18 Oct 2009, 21:43
The black section on mine is the R&G tail tidy the oem has a bloody huge arm hanging off the arse. the part the yank has fabricated is the part i need your tail to make a mould from to create the same thing, because of the pain in the arse and the tightness of the tail on mine I do not want to tempt fate taking it off and on to build the underside and end up damaging it getting it on or off.
I will treat your panel as if it was my own and it will be protected Smile
PM sent with addy.
Male Age : 43
Post by Kaiser on Wed 21 Oct 2009, 09:38
Keep us posted Russ would be good to see the outcome mate
Post by Deathace on Sat 24 Oct 2009, 10:17
Pods red:
Pods red with decals:
Pods red with decals and future tail shaved:
Abortion of red (front air ducts with decals and pods):
Existing bike with shaved tail mod which will be done over the winter:
Male Age : 43
Post by Deathace on Mon 26 Oct 2009, 09:36
just to clarify the photoshops of the pods and airducts was an exercise i did to rule out doing them as too much red just spoils the lines of the bike, the tail I do want to do but even then I am dubious Smile
Male Age : 43
Post by Kaiser on Mon 26 Oct 2009, 10:41
How easy is it to remove the headlights & install the dark lensesmate ?
Post by fastbikefinder on Mon 26 Oct 2009, 11:07
Kaiser wrote:How easy is it to remove the headlights & install the dark lensesmate ?
They're external covers
Post by Kaiser on Mon 26 Oct 2009, 11:11
That would make it a little easier than eh
Post by Deathace on Mon 26 Oct 2009, 13:27
Yeah external lense protectors they do them for your model as well Smile
Male Age : 43
Post by Kaiser on Mon 26 Oct 2009, 17:50
Honda ?
Post by Deathace on Mon 26 Oct 2009, 18:45
nah I bought mine from EVL Plastics but powerbronze do them as well, I like EVL plastics they are well made and for 20 cant go wrong for protection for your lights against stone chips.
Easier to replace 20 quid protectors than 600 quid headlights.
Male Age : 43
Post by Kaiser on Tue 27 Oct 2009, 08:53
I agree bud
Post by Kaiser on Wed 28 Oct 2009, 10:27
Russ,
Did you have to remove the headlights to fit ?
Or can you place without doing that ?
Post by Kaiser on Wed 28 Oct 2009, 10:28
Are your's dark or light smoked so I can take a judgement call ?
Post by Deathace on Wed 28 Oct 2009, 11:03
Mine are dark smoke so the light still passes through them they are fixed over the top whilst the headlights are in situ, just use the velcro that comes with them to position it correctly to support all edges.
If you look at this photo you can see the lights on and where I fixed the velcro (made of plastic and very strong).
Male Age : 43
Post by Kaiser on Wed 28 Oct 2009, 11:06
Thanks Russ
