gear indicator
gear indicator
Post by helrazzer on Mon 10 Aug 2009, 20:48
i just fitted gear indicator to my bike, but have a problem when in neutral all was ok but when i engaged 1st gear neutral light gets dimmer but is still alight No i checked all wireing seems ok)) any ideas?
Number of posts : 179
My bike(s) : cbr1000rr 09, 94 blade streetfighter
Registration date : 2009-05-01
Re: gear indicator
Post by masterblader on Mon 10 Aug 2009, 21:41
When 1st gear selection is made the neutral light should go out as this is triggered by the gearbox selector drum. The neutral light (dimmed) staying on is a clear sign that there is a backend feed reaching the neutral light. If thats the case this backend feed could effect other functions on the bike yet to show itself.
Re: gear indicator
Post by helrazzer on Mon 10 Aug 2009, 21:48
but when gear indicator is disconected it works fine
Re: gear indicator
Post by reeseyboy on Mon 10 Aug 2009, 21:50
If you are absolutely sure that your connections are good, change the neutral switch (they're only about a tenner). When I fitted an indicator to my 954 my neutral light played up, changed the switch and all was good.
reeseyboy
Number of posts : 207
My bike(s) : 2009 CB1000R - Sword Silver
Registration date : 2009-05-26
Re: gear indicator
Post by helrazzer on Mon 10 Aug 2009, 21:51
ill try that thank u
Re: gear indicator
Post by griz on Wed 12 Aug 2009, 10:10
Hiya!
Is that the one I sold you or a new one?
Re: gear indicator
