My 08 Blade Mods.
Page 2 of 2 Previous  1, 2
Re: My 08 Blade Mods.
Post by Guest on Wed 25 Nov 2009, 19:41
Lookin good so far Russ.
Post by griz on Wed 25 Nov 2009, 20:17
Looking good russ!!
Thats how I learned, in at the deepend! I think it's the best way to go about it
Are you going to coat the bare CF with clear resin??
Post by cabbie on Wed 25 Nov 2009, 20:40
I couldn't be asked to start making parts from carbon fibre, far too messy for my liking
Hope it turns out well for you, looks good so far
Post by Fringe on Wed 25 Nov 2009, 22:55
Looks great m8.
keep up the good work and the pics,
they spur us all on to have a go too
Post by fastbikefinder on Thu 26 Nov 2009, 07:38
Great work mate, keep it up.
Post by Deathace on Thu 03 Dec 2009, 21:18
Done a bit more tonight and posted about it but for some strange reason its not here now????
anyway here are the pics.
Number of posts : 509
Post by griz on Fri 04 Dec 2009, 11:34
Lookin good russ, how many layers did you use?
Post by Guest on Fri 04 Dec 2009, 11:50
lookin good Russ
Post by Deathace on Fri 04 Dec 2009, 15:11
I was planning on only using 2 layers but alas I totally cocked that piece up earlier when I marked it up for trimming wrong so back to the drawing board :(
However can anyone suggest a national business that sells sheet metal what I am going to do for the next one is make the template out of metal and make another one a bit bigger to go over the top and then when I lay up the carbon squash them together with clamps to keep it flat and compacted.
I am only after some 1mm or 2mm tin or copper perhaps or anything similar that will bend easily enough but retain its shape. Unless anyone has a better idea I can pinch?
Post by Deathace on Fri 04 Dec 2009, 16:27
I managed to get some 2 mm ali plate for a few quid off local fabricators so will see how that goes, got another place getting me some 1m galvy to use in the event of this not being good enough to use.
Post by griz on Fri 04 Dec 2009, 18:26
Sounds like you have a bit of a plan there mate!
Dunno much about making stuff like that but do a search on utube at vacuum bagging as I think this is the best way to make the CF hold it's shape
Post by Deathace on Fri 04 Dec 2009, 22:13
I looked in to vacuum bagging and funny that I have some vacuum bags here from when we went on holiday so "ghetto or not" its worth having a play with some of the smaller ones once in the mould, thanks for the reminder.
Post by Deathace on Sat 05 Dec 2009, 14:43
I put mine back on the dyno this morning to see how things had changed since putting the blue flame exhaust on and it wasnt as drastic as I first suspected, It is running leaner now but this is with no power commander just a straight swap, the power and torque are marginally affected but it should be fine for the odd few rides I have between now and feb when I get the PCV and custom tune done.
Sounds lovely in the flesh video off the phone just doesn't do it justice, but I like me videos so here it is Smile http://www.youtube.com/watch?v=DcDWYZmeCmA
Steve @ Seastar will do his best to dial it out and we can go from there, overall very pleased with the results at least I know its not going to knacker the injectors on it whilst riding in the mean time I just have to pick a lower gear and sit higher in the revs Smile
