Headlights
Headlights
Post by Fringe on Mon 23 Mar 2009, 09:45
Can anyone tell me the MOT settings for the headlight beams.
I've p*ssed about with my fairing and I dont think the headlight beam spread will pass MOT. digging
I the 'OLD' days I used to set the front wheel a measured distance from me Dad's Garage doors, Draw a Chalk line on the doors then adjust the beams by hand.
I've forgotten the measurements. scratch screwy
ta
Re: Headlights
Post by alsieboy on Mon 23 Mar 2009, 10:01
Here you go matey, an excellent site that lists the Mot procedure
http://www.ukmot.com/bike/1-6.asp
Re: Headlights
Post by Fringe on Mon 23 Mar 2009, 13:58
Ta m8
Re: Headlights
Post by Fringe on Mon 23 Mar 2009, 14:02
Bloody ell now I'm confused. Lol
Re: Headlights
Post by alsieboy on Mon 23 Mar 2009, 14:24
Alternatively...
Getting a correctly aimed headlight is straightforward. You need to make a couple of measurements and then aim the light at a flat wall, as follows:
With the bike upright on its wheels (off the side or center stand) and your weight in the seat, have a helper measure the distance from the floor to the center of the headlight lens.
Pick a flat wall where you can locate the bike on level ground so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two (2) inches lower than the height of the center of the headlight.
With you again sitting in the seat adjust the vertical screw (usually at the very top or very bottom of a headlight next to the lens but inside a trim ring) so the flat top of the low beam is just to the line you put on the wall (a two inch drop at 17 feet).
The horizontal adjustment (screw will be on the left or right side of the headlight lens) should center the beam ahead of the line of the bike.
Re: Headlights
Post by Fringe on Mon 23 Mar 2009, 14:33
LOL Thasss Be'errrr.
I understand That clap
Thanks m8
Re: Headlights
Post by alsieboy on Mon 23 Mar 2009, 15:47
No worries, glad to help sunny
Re: Headlights
