Cam chain tensioner tools
Post by fastbikefinder on Mon 09 Mar 2009, 10:50
Ok, the blade manuals say you need the special Honda tools
07ZMG MCAA400
OR
07NMG MY90100
.......to hold the cam chain tensioner at the limit of wear to your chain.
This is a 20 tool, which is T shaped and 1mm thick!
I found that in the 929 manual there is an instruction diagram as an alternative to using the Honda tool.
So if you're into a bit of spannering your self, and you are going to change shims after a valve check , or your just a bit strange like me and want to check your tensioner operation then save your self 20 and make one of these beauties.
Re: Cam chain tensioner tools
Post by Guest on Mon 09 Mar 2009, 10:59
You're a genius mate, a man after my own heart, do it yerself!
Post by fastbikefinder on Mon 09 Mar 2009, 11:23
megawatt wrote:You're a genius mate, a man after my own heart, do it yerself!
It has to be done mate!
I was contemplating buying one from Silver's but it was niggling away at me exactly what and how it does it, at first I was going to use a small screwdriver, but then I'd have to hold the screwdriver in place whilst I bolt the tensioner back on etc, which would be a tall order considering the amount of room you have as the tensioner is right by the frame spar cradle.
45 mins research this morning and I saved myself, and hopefully a lot of others 20!
Post by timmr6 on Sat 12 Sep 2009, 19:59
i just got my old man to hold it with a screwdriver while i tightened up the bolts, worked for me.
although i will have to remove it again to install a new one Smile
timmr6
Number of posts : 25
My bike(s) : 94 cbr 900 rrr fireblde
Registration date : 2009-09-07
Post by fastbikefinder on Mon 14 Sep 2009, 01:20
timmr6 wrote:i just got my old man to hold it with a screwdriver while i tightened up the bolts, worked for me.
Your lucky,
On the RR's there's no room for anything longer than a match stick to get in there
