GSXR 600 K5 tail conversion + quite a bit more in the end.
Page 3 of 14 Previous  1, 2, 3, 4 ... 8 ... 14  Next
Re: GSXR 600 K5 tail conversion + quite a bit more in the end.
Post by 1992fireblade on Sun 07 Dec 2008, 08:37
Thats coming on mighty fine cabbie!
I do look forward to visiting this thread on a daily basis.
Post by Fringe on Sun 07 Dec 2008, 16:01
I gotta admit I'm hooked on this thread too.
Fine job m8.
's gonna look like it grew there.
Post by cabbie on Sun 07 Dec 2008, 20:42
Next I drilled and fitted a 3mm nut & bolt to each hinge arm to limit the opening, don't want to scratch the nice new cowl now do we, lol.
Here's the pod inner piece
And here's the latch I made
And here's the latch bolted to the modded pod inner piece
IT WORKS, lol a little pressure and it click shut and when the latch is released it pops open an inch, nice
This is the other reason I made a new hinge, I needed it wider to fit the battery between the arms, next job is mounting the battery.
Post by Jollygiant on Mon 08 Dec 2008, 01:36
Doing a good job there.
Things are a lot easier when you've go the right tools and space to do it.
Wish i had a nice garage full of tools. No
Post by cabbie on Mon 08 Dec 2008, 18:57
Next up is the front seat fixing, I'm using the rear seat latch thing, I need to mount it about here
Here's what I'll cut out to mount it
Post by 1992fireblade on Wed 10 Dec 2008, 16:35
Cabbie did you have last night off? Lol. eyebrow
I logged in for my daily installment on the "progress of a genius" & to my disappointment there was nowt! pullhaur2
Hope you are going to make up for it tonight buddy! Lol. digging hyper
Post by cabbie on Wed 10 Dec 2008, 17:18
Sorry, the fuse popped on the milling machine and I didn't have a spare.
Post by wild bill on Wed 10 Dec 2008, 18:10
cabbie wrote:Sorry, the fuse popped on the milling machine and I didn't have a spare.
Flippin amateur lol!
Sorry cabbie, couldn't resist 118
Post by 1992fireblade on Wed 10 Dec 2008, 18:16
Surely a man of your calibre could of made one or improvised???
Tin foil works a treat!.................. Apparently scratch
Post by Guest on Wed 10 Dec 2008, 18:27
Six inch nail lasts longer?
Post by cabbie on Wed 10 Dec 2008, 20:12
Finished cutting the mounting
Drilled and countersunk the subframe
Fixed mounting to subframe
Fixed latch thing to mounting
Made latch cable shorter
Post by alsieboy on Wed 10 Dec 2008, 20:49
Im hooked on this too, amzing sunny
Post by mr pie on Wed 10 Dec 2008, 21:49
This thread should be a sticky.
well done Cabbie thanks for taking the time to post and document.
Number of posts : 1251
My bike(s) : Bandit 600, CBR RR3 954
Registration date : 2008-02-08
Post by 1992fireblade on Wed 10 Dec 2008, 21:58
I feel so much better now I have had my daily fix! Cheers cabbie
Post by cabbie on Wed 10 Dec 2008, 22:05
Second update for the missing one last night hyper
Fixed the rear seat mount
With the cowl on
With the seat in it's fixed location, I bolted the subframe to the tank and it looks ok, there is a slight gap so a small triangle piece might be needed or lengthen the seat.
I cut down the latch thing
Just need to mount it under the seat now, Any ideas how?
Post by cabbie on Wed 10 Dec 2008, 23:30
Made a cable holder from 16mm nylon round bar
Post by cabbie on Thu 11 Dec 2008, 18:06
Next job is making some support blocks for the seat, the seat would have sat on the gsxr subframe but not on the blade subframe
I needed to make the blocks a wedge shape too, I was sent some free blue stuff so thought it would do for this job
Here's the seat support blocks fitted
Post by cabbie on Fri 12 Dec 2008, 22:38
Sorry, no update I'm going to the titty bar.
Post by wild bill on Fri 12 Dec 2008, 23:08
Where man where? drool
Post by 1992fireblade on Sat 13 Dec 2008, 09:02
How about some titty bar pictures then dude to keep the troops happy???
Post by cabbie on Sat 13 Dec 2008, 09:09
1992fireblade wrote:How about some titty bar pictures then dude to keep the troops happy???
Pix are not aloud but you can have a look here
http://www.spearmintrhino.co.uk/clubhome.php?clubID=2
Post by cabbie on Sun 14 Dec 2008, 00:05
Next job is installing the front seat release cable etc, I made up a cable the right length
I made another cable holder
Next I made a small thumb lever and pivot
All fitted and working
Post by cabbie on Sun 14 Dec 2008, 23:14
Didn''t get any time to play with the tail unit this weekend
Next the seat needs two support blocks at the front, there is a latch being fitted but this won''t be strong enough to stop side and up/down movements,
Here''s the area need to the bridged
Again I find fabrication parts like this best done with card
Once all the dimensions are known you can transfer them to the material being used, I''ll get this cut tomorrow and fitted
Post by alsieboy on Sun 14 Dec 2008, 23:22
GOBSMACKED hubba
Post by Jollygiant on Mon 15 Dec 2008, 00:08
Just wondering how your going to get to the thumb lever for the seat when the seats on.
The seat will be covering the lever won't it. Or is there enough room to get a finger between the seat and plastics to operate it??
Post by cabbie on Mon 15 Dec 2008, 08:17
Jollygiant wrote:Just wondering how your going to get to the thumb lever for the seat when the seats on.
First use the key lock on the side of the tail unit to open the pod, when the pod is open I can operate the thumb lever to remove the riders seat.
Post by cabbie on Wed 17 Dec 2008, 23:21
So next job to do is make some front seat blocks to hold the seat in place.
Here's the gap that needs filling
I made two blocks to fit with the measurements taken from the cardboard pieces cut out in the last post.
Here's how they will look when they are fixed in place, hopping to get that done tomorrow and fit the latch thing
Post by cabbie on Fri 19 Dec 2008, 22:38
I've drilled the frame and drilled and tapped the blocks
Block mounted
All looks good with the seat in place
Next job is to bridge the 18mm gap and fabricate a bracket to mount the latch thing to the seat
Post by cabbie on Sat 20 Dec 2008, 00:53
I made a start on the latch thing bracket
Just need two 6mm spacers and work out how to fix the bracket to the seat
Post by cbr9rrnut on Sat 20 Dec 2008, 12:29
I think everything I've seen so far is the definition of craftsmanship.
Hats off to you cabbie, the end results will be stunning
Number of posts : 127
Male Age : 33
My bike(s) : Suzuki DR-Z400SM K5
Registration date : 2008-08-25
