Wiring
Wiring
Just about to put the wiring under the tank and have heard about issues with blocking the air filter scoops, I've taken the air box off and gonna put it in the gap at the front. Anybody got any advice?
cub- CBT Novice
- Number of posts : 84
Re: Wiring
The air well behind the headstock has the deflector bolted on, if this cavity is obstructed it will impede the air flow. As road speed increases the air speed increases as well causing a vortex effect this swirl slows down the air speed so the motor can get the correct air/ fuel throughout the rev range.
If the deflector is removed and the cavity obstructed the motor will run poorly and will struggle higher in the rev range.
Re: Wiring
Cheers mite try and put the wiring to the side or nbetween the scoops.
cub- CBT Novice
Re: Wiring
Some fancy cut and soldering would be needed, most of the wiring could run under the cross member whilst the relays and fuse box on the top. Good luck bud
Re: Wiring
Interesting. Was wondering what to do with the wiring.
Was thinking shorten a lot of it to save trying to hide it.
Wee Al B- Clubman Racer
- Number of posts : 184
My bike(s) : 1998 Blade, 2003 CB1300
Registration date : 2010-03-23
Wiring
Shortened 95% of the wiring just the speedo to wire in and get the lot set up right around the scoops. Amazin how much you can lose!!
cub- CBT Novice
Re: Wiring
Great job there Cub.
Most SF riders shy away from the cut and solder just in case they need to revert back to standard set up at the expense of performance.
One guy found his bike ran quicker with the front wheel pawing the air
Re: Wiring
Don't imagine mine will ever make it back to standard
Wiring
Mines probably wont either. I'm not great with electrics only doing it one block at a time, but as long as it's soldered and sleeved then it should be okay. Probably the hardest job on the mods this year. SO FAR !!!!
cub- CBT Novice
Re: Wiring
The wiring's the only bit I'm not too worried about as I'm a spark to trade
Re: Wiring
Now you've let it slip you'll probably be pretty busy
cub- CBT Novice
