The Bear's FireBlade
+3
7 posters
jallen- Admin
- Number of posts : 1750
Re: The Bear's FireBlade
The poor thing left out in the rain well at least it not chained up to some pole I guess!
The more I see an Original Blade, the more I want one! either this colour or the black one with the silver/grey graphics....
......hhmmmmm got me thinking now, tigger is still being worked on to make her even cleaner (if that is possible) so I think it's time to pursuade her indoors I need another!
Firebladeradmin- Website/Forum Owner
- Number of posts : 3124
Registration date : 2007-07-19
Lovely bikes them
That is a nice example of an early Blade..........
Get the grinder out!
where abouts are you in northants mate? I have an annoying rattle that i would like you to have a listen to.
cheers
the bear
cheers
the bear
the bear- Trackday Novice
- Number of posts : 127
My bike(s) : 1993 blade
Registration date : 2008-06-09
Im in Wellingborough.
All the early Blades have an annoying rattle mate.
Does it rattle from about 5000rpm by any chance?
err yes!
boos down a bit as well, you have to rev through a bit of spluttering. Could be because it had been sat in a showroom for a couple of years.
Oh, i'm in long buckby but working in wellingborough on monday
Is the choke functioning properly?
I presume the inlet rubbers are in good condition & air tight.
Mine had a bit of a rattle which was the cam chain tensioner but doesnt cause a flat spot or splutter.
When was your Blade serviced last mate?
err, 18/03/06 oil and filter (was going to change oil this weekend)
new cam cahin tensioner fitted 26/02/02 (2,500 miles ago)
Post a thread in the CBR900RR 1992-1999 section & im sure somebody a lot more technical minded will come up with the answer.
How long was the bike standing? I rebuilt a vfr400 that had been standing for 18months and the choke assembly needed stripping and cleaning plus petrol had solidified in the carbs and jets, making it fail to run.
Then the rubbers had hardened and were misshaped causing too much air to be sucked in, plus I know it's seem obvious but when were the plugs last changed?
according to receipts, it had a full service (including plugs) in 22/02/01 at 14,918miles
now done 23,000miles.
perhap a good service needed
the bear wrote:according to receipts, it had a full service (including plugs) in 22/02/01 at 14,918miles
LAST PLUG CHANGE 7 YEARS AGO..!!!!
I think a service would def be a good idea,
alsieboy wrote:the bear wrote:according to receipts, it had a full service (including plugs) in 22/02/01 at 14,918miles
lmfao @ alsieboy!
ok, change oil and run a wire brush over plugs it is then
