The Bear's FireBlade
Post by jallen on Thu 19 Jun 2008, 21:18
Re: The Bear's FireBlade
Post by Blade_Hog on Fri 20 Jun 2008, 07:36
The poor thing left out in the rain well at least it not chained up to some pole I guess!
Post by alsieboy on Fri 20 Jun 2008, 08:35
The more I see an Original Blade, the more I want one! either this colour or the black one with the silver/grey graphics....
......hhmmmmm got me thinking now, tigger is still being worked on to make her even cleaner (if that is possible) so I think it's time to pursuade her indoors I need another!
Post by Firebladeradmin on Fri 20 Jun 2008, 08:46
SNAP thumbup
Post by stuart on Fri 20 Jun 2008, 09:04
Lovely bikes them
Post by 1992fireblade on Fri 20 Jun 2008, 18:46
That is a nice example of an early Blade..........
Get the grinder out!
Post by the bear on Fri 20 Jun 2008, 19:05
where abouts are you in northants mate? I have an annoying rattle that i would like you to have a listen to.
cheers
the bear
the bear
Number of posts : 127
My bike(s) : 1993 blade
Registration date : 2008-06-09
Post by 1992fireblade on Fri 20 Jun 2008, 19:09
Im in Wellingborough.
All the early Blades have an annoying rattle mate.
Does it rattle from about 5000rpm by any chance?
Post by the bear on Fri 20 Jun 2008, 19:27
err yes!
boos down a bit as well, you have to rev through a bit of spluttering. Could be because it had been sat in a showroom for a couple of years.
Oh, i'm in long buckby but working in wellingborough on monday
the bear
Post by 1992fireblade on Fri 20 Jun 2008, 19:33
Is the choke functioning properly?
I presume the inlet rubbers are in good condition & air tight.
Mine had a bit of a rattle which was the cam chain tensioner but doesnt cause a flat spot or splutter.
When was your Blade serviced last mate?
Post by the bear on Fri 20 Jun 2008, 19:39
err, 18/03/06 oil and filter (was going to change oil this weekend)
new cam cahin tensioner fitted 26/02/02 (2,500 miles ago)
the bear
Post by 1992fireblade on Fri 20 Jun 2008, 19:43
Post a thread in the CBR900RR 1992-1999 section & im sure somebody a lot more technical minded will come up with the answer.
Post by alsieboy on Fri 20 Jun 2008, 22:14
How long was the bike standing? I rebuilt a vfr400 that had been standing for 18months and the choke assembly needed stripping and cleaning plus petrol had solidified in the carbs and jets, making it fail to run.
Then the rubbers had hardened and were misshaped causing too much air to be sucked in, plus I know it's seem obvious but when were the plugs last changed?
Post by the bear on Sat 21 Jun 2008, 00:09
according to receipts, it had a full service (including plugs) in 22/02/01 at 14,918miles
now done 23,000miles.
perhap a good service needed
the bear
Post by alsieboy on Sat 21 Jun 2008, 15:25
the bear wrote:according to receipts, it had a full service (including plugs) in 22/02/01 at 14,918miles
LAST PLUG CHANGE 7 YEARS AGO..!!!!
I think a service would def be a good idea, sunny
Post by 1992fireblade on Sat 21 Jun 2008, 15:44
lmfao @ alsieboy! Laughing rofl Laughing
Post by the bear on Mon 23 Jun 2008, 22:34
ok, change oil and run a wire brush over plugs it is then
the bear
