04 1000 rr seat unit and rsv swing arm onto rrv
+16
kavanaj
CBR900RR-P
stephen918
nickyboy
Cove
morpheus20170
20 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Well now that i am off the road for a bit due to having a op on my sholder i thought now is the time to get the blade sorted.So started today after pickin up the seat unit from Andy (Cove),thanks mate hope the move works out ok, any way was going to leave it till sholder was a bit better but then thought stuff it lets get on with it got the old tail unit and subframe of and set about chopping a spare subframeto get the 04 one to fit but then after fitting it to the bike the seat unit sat way to low so tomorrow i am going to set about chopping the subframe a bit more till i am happy with it. i dont have much free cash at the mo so its all
going to be done on a budget of not a lot but i am sure i will get there with it as it aint going back on the road till its all done. I have a few bits still to find like undertray and seat cowl so if any one has any of the two feel free to drop me a pm,anyway here are a few photos to be going on with will post up more as i go
scotty80- Website/Forum Owner
- Number of posts : 846
Re: 04 1000 rr seat unit and rsv swing arm onto rrv
Well got a little bit done today sorted the subframe out just got to make some proper brackets to mount the seat unit to then get it welded then modify the gsxr 1000 undertray to fit sort out the battery box.
got a dilema do i paint the rest of the body work the same as the repsol bits thats on it or do the seat unit and front fender to match how it is now
Have just bought a 04 rsv swing arm rear caliper and the bloke has gave me new caliper bolts to and carbon swing arm covers well happy andn cheep to witch is good
If I can help with anything just call me.
Hope you get better soon mate and get to ride that new bike just like you rode the old one.
morpheus20170- WSB Racer
- Number of posts : 521
My bike(s) : Honda CBR600RR-07 (stolen) Honda CBR1000RR-06
Registration date : 2010-10-31
cheers matemorpheus20170 wrote:If I can help with anything just call me.
well here is some pics of the frame with the rsv swinger in big thanks to cabbie for all your help ignore the hugger it looks crap
That;s looking gr8.
The Standard seat looks a bit fat to me but at least you wont get a numb bum.
thanks m8,ye have got a rr4 one that i will use when it turns up
does that rsv swinger fit straight in with no mods?
Well heres what i got done today made up a new link pipe and can and got the seat unit secured to subframe should have it all ready to go tomorow if i can get my hands on a soft link for the chain
danidge wrote:does that rsv swinger fit straight in with no mods?
no mate you have to shave a bit off the right hand side of the frame to get it to go in
oh right, i only ask because i thought i saw somewhere else that they go straight in. doesn't seem too much to do tho
looking good man
looking good man
cheers matemegawatt wrote:Looks great George!
That seat really suits the bike and the angle of the pipe is mental. (in a good way, )
Well it is done for the time being till i can aford to paint it but at least its on the road,got to do somthing to the exhaust as its oh my god LOUD
Great to see the bike hit the road Scotty but did she have a leak at Hellrazzers place!!!!!!!!!. What was the ride like in terms of engine and handling etc:
masterblader wrote:Great to see the bike hit the road Scotty but did she have a leak at Hellrazzers place!!!!!!!!!. What was the ride like in terms of engine and handling etc:
No leak mate,goes like stink lol
What have you done with the battery and all the electrics george?
Cove- Superstock Racer
- Number of posts : 226
My bike(s) : CBR900RR Bitza Blades
Registration date : 2009-07-09
I used the under tray that come with the subframe battery fits ok got to have a bit of a sort out with the loom and bits but its all in ok for the moment and will do a proper job when i paint itCove wrote:What have you done with the battery and all the electrics george?
Mine looks messy as anything at the moment was thinking of extending my positive an negative battery lead and putting it under pillion seat, and leaving reg rec cdi and starter solenoid to where it is dont fancy chopping the loom about.
How did you get on with the swinger ??Cove wrote:Mine looks messy as anything at the moment was thinking of extending my positive an negative battery lead and putting it under pillion seat, and leaving reg rec cdi and starter solenoid to where it is dont fancy chopping the loom about.
Can make you a baffle for that can George? Just need accurate dimensions???
megawatt wrote:Can make you a baffle for that can George? Just need accurate dimensions???
i am going to try and do something with it tomorrow as it has one in it but its shit,will be comin down you way next weekend if you are about??
Typical, I'm on 12 hour nights next weekend! Will be around on Friday afternoon though. Gimme the dims and I'll see what I've got lying around. Got some 37mm perforated tube???
Its on and working but i'm not happy with it at the moment, have found some 16mm rose joints Going to make up an adjustable turnbuckle to replace the dogbone, just need to get some steel bar drilled or cds tube with an internal diameter of 22mm.
Scotty, did you use the standard blade shock triangle, or the one from the aprilla swingarm?
nickyboy- BSB Racer
- Number of posts : 401
My bike(s) : 1997 Honda Fireblade RR-V Italian Import
It has the standard blade triangles and shock but you have to make up spacers so it all lines up, have sent you a pmnickyboy wrote:Scotty, did you use the standard blade shock triangle, or the one from the aprilla swingarm?
» In addition to the R1 arse
» R1 Seat Unit
» Single sided swing arms
» single sided swing arm
» RRW rear swing arm conversion
» R1 Seat Unit
Page 1 of 3
