How to change Tyres and balance Wheels
Post by chilli on Tue 06 Nov 2007, 16:16
I was going to do my own write up on how i would do tyre changes and wheel balancing, however i came across this "How To" on the tinternet and i couldnt match this for its great info and pictures.
http://clarity.net/~adam/tire-changing-doc.html
Re: How to change Tyres and balance Wheels
Post by Guest on Tue 06 Nov 2007, 16:30
Thats a good find there chilli
Post by legins on Tue 06 Nov 2007, 17:51
Great find
Post by fastbikefinder on Sun 01 Mar 2009, 06:20
That is a god find but the tyres light spot is generally fitted inline with the valve.
Also, a really really good way of checking the balance once the tyre is on, and will save you buiding a wooden frame is to use 2 adjustable jack stands, especially as the jack stand struts are generally shaped concaved so your axle will sit in it nicely.
Same principle, as the wooden frame - Put your axles/spindle into the wheel without the spacers and sit it into an axle stand each side, The perfect way - also aids cleaning of your wheel before it goes back on the bike.
