rsv Aprilia swingarm in to 97 fireblade
rsv Aprilia swingarm in to 97 fireblade Empty rsv Aprilia swingarm in to 97 fireblade
Post by Phil C Sun 10 Feb 2013, 11:13
Hi
I am new to the forum and need advice on fitting a Aprilia rsv swingarm in to my streetfightered 97 fireblade, what year of rsv swingarm will
fit best and will i be able to use the fireblade rear wheel disc ect any advice will be helpful thanks:)
Phil C
Phil C
Number of posts : 5
My bike(s) : 97 fireblade
Registration date : 2013-02-10
rsv Aprilia swingarm in to 97 fireblade Empty Re: rsv Aprilia swingarm in to 97 fireblade
Post by cabbie Sun 10 Feb 2013, 14:30
Just get an 04 Mille swinger, grind off 4mm from the right inside boss on the frame, arm will go straight in with the blade hardwear.
Get some longer 8mm bolts and a pack of washers to realign the suspension linkage, job done.
Don't bother trying to fit the blade wheel unless you have a lathe and good fabrication skill's, just get a set of cheap Mille wheels.
rsv Aprilia swingarm in to 97 fireblade Empty rsv swingarm
Post by Phil C Sun 10 Feb 2013, 15:58
cabbie wrote:Just get an 04 Mille swinger, grind off 4mm from the right inside boss on the frame, arm will go straight in with the blade hardwear.
Thanks for the info will get on and try and track some parts down , when you say the right side of the frame is that the clutch side if you
look from the back .
Phil C
Phil C
Number of posts : 5
Post by cabbie Sun 10 Feb 2013, 16:04
Yep, you don't have to get it perfect just as long as the swing arm goes in the gap, the screw in spacer touches the swinger.
Post by Phil C Sun 10 Feb 2013, 16:43
cabbie wrote:Yep, you don't have to get it perfect just as long as the swing arm goes in the gap, the screw in spacer touches the swinger.
Thanks mate is the 2005 rsv swingarm the same as 2004 and will 2003 wheel fit.
Phil C
Phil C
Number of posts : 5
Post by cabbie Sun 10 Feb 2013, 16:51
2004 swing arms are recall's but you just need to weld up a rivnut hole to make it safe, 2005 are the new design swinger, not sure about the 2003 wheels, go look at the Mille microfiche and see if the wheels are the same part numbers, I think they should fit ok.
Post by Phil C Sun 10 Feb 2013, 17:55
cabbie wrote:2004 swing arms are recall's but you just need to weld up a rivnut hole to make it safe, 2005 are the new design swinger, not sure about the 2003 wheels, go look at the Mille microfiche and see if the wheels are the same part numbers, I think they should fit ok.
Can not find a decent 04 arm but found a 05 just wondered if the 03 wheel will fit
Phil C
Phil C
Number of posts : 5
Post by cabbie Sun 10 Feb 2013, 18:25
Check the part numbers on the 03 and 05 wheels, if the part numbers match the wheel will fit.
Post by Phil C Sun 10 Feb 2013, 19:10
cabbie wrote:Check the part numbers on the 03 and 05 wheels, if the part numbers match the wheel will fit.
Thanks mate will look in to it.
Phil C
Phil C
Number of posts : 5
Post by womack616 Wed 09 Apr 2014, 23:14
I know this post is a year old. But does anyone know how difficult it is to fit the matching Aprilia wheel on the front of the same bike with the 1000rr fork conversion?
womack616
womack616
Number of posts : 1
My bike(s) : 94 CBR 900RR
Registration date : 2014-04-05
