09 streetracer
Page 2 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Re: 09 streetracer
Post by lambchops on Mon 04 Mar 2013, 21:56
Very nice Cabbie! Im just about to order some samcos for mine, bloody expensive arnt they!!
Re: 09 streetracer
Post by cabbie on Mon 04 Mar 2013, 22:02
Probably, not sure how quick these bikes are as never ridden one but should be a giggle Smile
Re: 09 streetracer
Post by clive1286 on Mon 04 Mar 2013, 22:05
Think you'll be happy, my '05 repsol was awesome!
Re: 09 streetracer
Post by cabbie on Mon 04 Mar 2013, 22:08
I'm getting the HM quick shifter and PC 5 fitted at Farnhams, will get the motor sorted next winter, HRC cam's etc, would like to see 200bhp Smile
Re: 09 streetracer
Post by lambchops on Mon 04 Mar 2013, 22:12
Think its going to be mental Cabbie with the diet its been on as it is!! Smile
Re: 09 streetracer
Post by clive1286 on Mon 04 Mar 2013, 22:13
lambchops wrote:Think its going to be mental Cabbie with the diet its been on as it is!! Smile
You better get a spare license now!!!!Smile
Re: 09 streetracer
Post by masterblader on Mon 04 Mar 2013, 22:22
cabbie wrote:I'm getting the HM quick shifter and PC 5 fitted at Farnhams, will get the motor sorted next winter, HRC cam's etc, would like to see 200bhp Smile
There's free parking facilities at Biggin Hill Cabbie
Re: 09 streetracer
Post by lambchops on Thu 07 Mar 2013, 23:00
Re: 09 streetracer
Post by cabbie on Thu 07 Mar 2013, 23:10
Nice but I have a plain body kit arriving Tuesday, also have paint job designed ready, like to be different lol, thanks for the link though bro Smile
Re: 09 streetracer
Post by lambchops on Thu 07 Mar 2013, 23:15
Saw it and thought of you Smile Should have guessed you were after something bespoke
Re: 09 streetracer
Post by cabbie on Sat 09 Mar 2013, 17:35
Few more bits done
Shock fitted
Side covers back on after aqua blasting
Brakes done and new damper fitted
Having a problem, motor turns over fine but won't fire up, here's the connectors not being used, do I need to refit some of the standard leccy parts?
Re: 09 streetracer
Post by lambchops on Sat 09 Mar 2013, 18:02
looking great Cabbie, cant help on the connector front though sorry :(
Re: 09 streetracer
Post by cabbie on Sat 09 Mar 2013, 18:37
Tilt switch needs pluging back in Smile
Re: 09 streetracer
Post by Chimpy on Sun 10 Mar 2013, 05:43
cabbie wrote:Tilt switch needs pluging back in Smile
this story is getting familiar....... Wink
Female Age : 50
Re: 09 streetracer
Post by silverback on Tue 12 Mar 2013, 12:15
In the last picture, isn't that the plug you fit a Power Commander too, if so, that two should be together 'or am I on the wrong plug' DOH
Re: 09 streetracer
Post by cabbie on Tue 12 Mar 2013, 13:23
One is for rear lights and the other is for exhaust vavle servo, I just ordered a servo buddy to plug in where the servo has been removed as you get a fuel injection error on the clocks.
Re: 09 streetracer
Post by cabbie on Tue 12 Mar 2013, 16:26
taken all the intake flapper crap off and the exhast servo etc and got the FI fault light, bought a servo buddy, this stopped the light when the ignition is turned on but it keeps coming on when the motor is started! do I need to replace some of the intake parts?
https://www.youtube.com/watch?v=klveue_5kf0&feature=youtu.be
Re: 09 streetracer
Post by cabbie on Sat 16 Mar 2013, 09:02
Found the FI fault light problem, it was a small vacuum hose that had pulled off the bottom of the airbox when I fitted the Q/A throttle, all good now.
The BB plastics race body kit arrived and it's crap! going straight back, re ordering a fairing from Pro-Fibre and seat/tank from UK Road & Race, another week's wait :(
Re: 09 streetracer
Post by shadow on Sat 16 Mar 2013, 12:07
cabbie wrote:Found the FI fault light problem, it was a small vacuum hose that had pulled off the bottom of the airbox when I fitted the Q/A throttle, all good now.
I hope the pro-fibre is a better kit. Smile
Re: 09 streetracer
Post by cabbie on Sat 16 Mar 2013, 12:16
Couldn't be any worse than BB plastic's shit!
Re: 09 streetracer
Post by cabbie on Thu 21 Mar 2013, 18:12
Well what a difference with the Pro-fibre fairing compared with the BB Plastic crap, top and belly pan are perfectly smooth with no seams!
Decided to cut the back off the belly pan as don't need to catch any oil Smile
And straight out the box and on the bike with just a few holes to drill, simples, and delivered in 4 days!
Just waiting for the tank and seat from UK Road & Race
Re: 09 streetracer
Post by Chimpy on Thu 21 Mar 2013, 21:37
sherweetsherwooo!!
Female Age : 50
Re: 09 streetracer
Post by lambchops on Thu 21 Mar 2013, 21:48
wow that looks great Cabbie! Glad the quality was better, did sound bad the BB one, not on!
Re: 09 streetracer
Post by cabbie on Sat 23 Mar 2013, 14:03
Few hours in the garage to sort out the rear brake
Standard set up
Machined up some new bits
Modded swing arm, (welder is off today so couldn't get this welded on)
All done and saved 600 for the Brembo kit, happy days Smile
Re: 09 streetracer
Post by Haggler ™ on Sat 23 Mar 2013, 14:09
Do you think that screw/bolt will hold all that braking torque?
Haggler ™
Re: 09 streetracer
Post by cabbie on Sat 23 Mar 2013, 14:16
Once it gets welded to the swing arm yes lol
Re: 09 streetracer
Post by cabbie on Sat 23 Mar 2013, 14:23
Heres the same set up on a Mille, 8mm stud holds the bracket same as I have done
Re: 09 streetracer
Post by lambchops on Sat 23 Mar 2013, 15:39
Nice work cabbie saved a few quid there, can you for the RSV caliper also?
Re: 09 streetracer
Post by Chimpy on Sat 23 Mar 2013, 17:11
nice work lovely Smile
Female Age : 50
Re: 09 streetracer
Post by kevb on Sun 24 Mar 2013, 08:20
Cool ! Smile
Re: 09 streetracer
